what tyre pressure ...
[Closed] what tyre pressure for cx bike?
10 Users
riding a mixture of roads and frie roads
thanks
Posted : 13/08/2009 7:54 pm
I run my maxxis raze at about 65-70 psi for the same thing
Posted : 14/08/2009 7:49 am
I run my Conti Speed King 35mms at 85psi but I weigh 16 stone.
Posted : 14/08/2009 8:20 am
50-55ish off road, 60-65 mixed.
Posted : 14/08/2009 8:21 am
The eternal question. Cross races are full of people talking about what pressure to run. I'm light, so can usually get away with lower pressures. However, for those conditions I would say about 60psi but I usually run about 40-50psi.
Posted : 14/08/2009 8:24 am
 JoB
somewhere between pinch-flat and eyeball-rattling, YMMV
Posted : 14/08/2009 8:28 am
hmmm yeah JoB hit the nail on the head there
Posted : 14/08/2009 8:35 am
Exactly but it'd save the OP some pinch flats to get an idea of where to start 🙂
FWIW, for road and fireroad which should basically be smooth and non-technical I'd be running as much pressure as I could to make it roll better.
Posted : 14/08/2009 8:37 am
What JoB said!
For proper off-road use it's a really tricky balance between pinch flats or zero traction eyeball rattling, there's a very narrow band where it just feels right. For me (at just over 10st) it's about 70psi.
Posted : 14/08/2009 8:52 am
thems some high pressures. for cross racing I have run 30-35 on softer ground with normal tyres (at around 13 stone). but generally as JoB said. but i would go soft as you can.
Posted : 14/08/2009 9:27 am
 nbt
I run mine at 100psi, but I don;t race, I use it for commuting: road on the way in to work, 50/50 split road and off road on the way home. Might try a lower pressure but with 28mm tyres I doubt it'll make a huge difference to the comfort, but it might increase the risk of me pinch-flatting
Posted : 14/08/2009 10:09 am
By the way, if all you are doing is fire roads and tarmac then get some solid big touring style tyres on there and then you can run lower pressures.
Posted : 14/08/2009 10:22 am
You've mentioned pinch flats. Anyone been using tubeless on their cross bikes? Thinking of getting a rim strip from justridingalong and trying it out for the rear wheel on mine.
Posted : 14/08/2009 11:00 am
