What tyre pressure ...
[Closed] What tyre pressure - 29er content
6 Users
So I read the tyre wall for pressure guidance (40psi seemed to be in the middle of suggested range) and ended up blowing up a perfectly good inner tube (may have been to pressure gauge being dodgy).
What pressure do folks recommend for the 29er noobs?
I reckon I'm probably running them too high at the mo.
Steve
Posted : 31/05/2011 8:03 am
same as 26", why would it be any different? Depends on tire & width, your weight, how you ride, the terrain.
I think 30-40psi is what most "wheels on the ground" folk ride.
Posted : 31/05/2011 8:05 am
As above, similar to 26" (unless you're also swapping to tubeless in which case about 5 to 10psi less) for a given tyre size.
Posted : 31/05/2011 8:41 am
Usually around 26/28psi for me for 2.2 ACXs on a hardtail with 27mm wide rims and tubes, I'm 71kg. Having said that had them down to 22psi at Dalby last week, the bumps were killing me!
Posted : 31/05/2011 8:49 am
maybe youd trapped the inner in the bead/rim
I run 35psi in a 2.4" RR, 35mm rim, carbon forks, 40psi Ignitor out the back (Ti post) 95+Kg lard arse on top.
Posted : 31/05/2011 8:53 am
29er wheels, 35 to 40 psi!
Posted : 31/05/2011 9:11 am
