What type of spokes...
[Closed] What type of spokes do I need (Specialized Camber Evo 2015)
7 Users
One of the spokes broke on the wheel of my Specialized Camber Evo 2015 and I need to replace it.
I had a search for the Specs of the bike and all I could get on Spokes was "DT Swiss".
Do I just need to order a set of any DT Swiss spokes that are of the right length, would that work ?
Posted : 20/09/2016 9:44 am
I'm guessing that they're standard j-bend style spokes (with a 90 degree bend where the spoke sits in the hub flange), rather than straight-pull or anything else esoteric.
In this case, you'll just need to get a replacement spoke (no need for a full set) of the same length. DT and Sapim are both good brands, but I've never had any problems with ACI (which tend to be a fair bit cheaper). See what your LBS has in stock.
Posted : 20/09/2016 9:50 am
Don't have a local bike shop but the nearest Halfords didn't have a clue. Think I might order a set of DT Swiss spokes online then at least I've then got spares.
Posted : 20/09/2016 9:57 am
Dony just order a random set of spokes , if you don't want to take one out to measure , you could measure with a steel ruler one of the ones still in the wheel and add a few mm to allow for nipple seat , not perfect but probably adequate.
If its a roval wheel , then officaly you need to detention before changing a broken spoke and retention , is your the entry level alloy evo ? 29 or 650.
Often it's the alloy nipple that fails and not the spoke , if you plan on keeping the bike it maybe worth replacing the alloy with brass
Posted : 20/09/2016 5:54 pm
Email Spesh uk and ask them for the part numbers, then ring nearest Spesh shop and ask them to order spares for you.
Posted : 20/09/2016 6:18 pm
Don't do this.
Specialized don't distribute it Swiss spikes, just go to a shop with your wheel/spoke and nipple measurements and they will gladly help you find the right one.
Most likely a DT comp but your not exactly going to notice if your new spoke is a few grams heavier
Posted : 20/09/2016 6:26 pm
Take the broken spoke off and measure it - if it has broken off at the thread, add 9-10mm to the length. If you're not confident, take it to a shop who know how to answer your question. Replacement spoke should only be 50p-£1.
Posted : 20/09/2016 6:34 pm
Not trying to come across as patronising or anything but you seem a bit confused about how to do this job . If you take the wheel to a LBS they will fit a new spoke and true it for possibly less money than buying a load of wrong length spokes . For future reference I would learn how to do this job yourself because once the alloy nipples start to go in these wheels it can become a pretty regular happening .
Posted : 20/09/2016 6:57 pm
Wiggles, did you read my post? I said ask Spesh uk for the part number and then when they give it to you order them through your nearest Spesh dealer.
I know this works because guess what, I just did it and got new spokes for my Stumpjumper.
Posted : 20/09/2016 7:18 pm
Spesh DO supply the some Dt swiss spokes as used in the roval branded wheels. But These are mainly straight pull ones. If your wheel is j bend then it's easy to find them as I said just measure them and go into any good shop.
Posted : 20/09/2016 8:29 pm
I measured the spoke and ordered the DT Swiss 302mm. Several ordered so I now have spares.
After fitting the spoke there is now a new problem. The wheel is buckled. Suppose it's gone worse because I've been riding it with a spoke missing for a while.
I've got zero knowledge of wheel truing and it sounds quite complicated so now I've got the misery of having to take it to & from a bike shop for sure now.
Posted : 26/09/2016 12:30 pm
