What tubeless repai...
[Closed] What tubeless repair kit?
5 Users
I have the Dynaplug carbon ultra lite kit but (as I found out on this morning's ride when I came to repair a puncture) have lost the metal sleeve that the plugs sit inside.
Unless anyone knows where I can get a spare, recommend me a reliable tubeless repair kit.
Cheers.
Posted : 27/05/2020 10:20 am
I use the Dynaplug Racer. Bits can't fall out of it, but you can lose the whole thing quite easily. 😭
Posted : 27/05/2020 10:36 am
What has worked best for me are the little Genuine Innovations kits.
The bigger Weldtite worm kit did work in the end after a fair bit of frustration where I either pushed the worm all the way through or pulled it right back out before finally getting one to stay in the hole.
What I now carry is a Dynaplug Megaplugger with the business end removed from the handle and hot glued into my OneUp EDC.  Has the advantage that it also came with fat and thin tube/plugs.  Happily I haven't used it yet and long may that last
Posted : 27/05/2020 10:49 am
Ive got the little genuine inovations kit. For a fiver its a bargain. Someone suggested sanding down thr handle and gluing into a bar end plug.
I've also got a kit off ebay intended for cars/motorbikes which has worms about 5mm thick and came with a big t-handle reamer and insertion tool! Thats more for the fat bike which has picked up whole sticks in the tyre before.
Posted : 27/05/2020 11:10 am
 pdw
Lifeline kit from Wiggle for £5. 10 worms in 2 sizes, insertion tool, knife and reamer.
Posted : 27/05/2020 11:28 am
