What tubeless ready...
[Closed] What tubeless ready rims for use with V brakes?
6 Users
As the subject says.
Looking to upgrade some wheels to tubless. These will be rebuilt onto existing hubs for a frame that doesn't have disc mounts.
Any advice?
Posted : 19/03/2014 10:01 am
Stans Cyclocross rims?
Posted : 19/03/2014 3:17 pm
Guessing that if it doesn't have disc mounts it's not a 29er...
In terms of actually being designed with tubeless in mind you'll struggle. The only options I can think of are the Stan's 355 and the DT X3.1, both long discontinued.
I'd get a rim of your choice and a conversion kit.
Posted : 19/03/2014 3:19 pm
Aren't 819s v-brake compatible?
Posted : 19/03/2014 3:23 pm
I'm looking at my 819's now and although there is about a 5mm lip it's half the size of a normal rim brake rim. I wouldn't use a rim brake on it.
Posted : 19/03/2014 3:59 pm
Ah, I'm behind the times- used to be a v-brake 819 but discontinued.
I know it's not exactly what you're after but I suspect my set (in an old Crossmax Enduro wheelset) are v-brake compatible, if that's any use...
Posted : 19/03/2014 4:04 pm
D'you know, I thought they discontinued the rim brake version of the 819 (the 819 being the X3.1), but that's a (heavy and expensive) option.
Posted : 19/03/2014 4:06 pm
try http://www.sjscycles.co.uk/ - they are pretty helpful and stock a lot of rims
Posted : 19/03/2014 5:05 pm
