what torque wrench?
[Closed] what torque wrench?
7 Users
okay, so bullet bitten- i decided i need to add a torque wrench to my tool collection if i want to follow through with certain plans i have.
but i have no idea what to get! there's a load on ebay but i'm not sure whether it'd be false economy buying, say, a draper wrench for <20 quid...
any advice on what i should be looking for/at?
cheers.
Posted : 06/06/2009 10:27 am
Trouble is, so much stuff on a bike is amazingly low torque, that even my pretty expensive 3/8 drive norbar is mostly useless. I could use it to torque up the cassette, but haven't a 3/8 socket big enough to fit cassette removal thingy so it's largely redundant.
Posted : 06/06/2009 10:34 am
ah, should have searched first. thanks drac!
Posted : 06/06/2009 10:36 am
I have one of these and it seems to work very well I havent bust any bolts using it.
[url] http://www.justoffbase.co.uk/Torque-Wrench-Micrometer-Style-1-4Sq-Drive-5-25Nm-44-221lb-in-Sealey-STW101?sc=9&category=918027 [/url]
[i]ah, should have searched first. thanks drac! [/i]
Just happen to see a couple of threads latterly.
Posted : 06/06/2009 10:42 am
that BBB one goes down to 2Nm which would seem to be low enough; will 24Nm be high enough for stuff that needs more torque on a bike though, or would i need to consider getting a second one (up to 70Nm or so)?
Posted : 06/06/2009 10:56 am
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=29803 ]BBB wrench[/url]. £55 on CRC but possibly cheaper on ebay if you can be arsed looking around.
2-24 NM range which covers most bike torque settings and comes with the most commonly used bits (allen key 3,4,5,6,8,10mm and Torx T25)
Seems pretty good quality too.
Posted : 06/06/2009 11:01 am
24 isn't going to cover cassette lock rings, bottom bracket cups or crank arms to name a few.
I've got the two park ones that seem to fit the bill.
Posted : 06/06/2009 11:02 am
It's fine for HTII style crank bolts (12-15NM) and for lockrings and BB cups and Shimano centrelock rotors I just use the appropriate tool and go "tight as ****"
Don't think there is one wrench to do all...
Posted : 06/06/2009 11:06 am
 goog
torque wrench indeed 🙄
just use the force 8)
Posted : 06/06/2009 11:18 am
