What steel Audax-ty...
[Closed] What steel Audax-type road bike would you recommend?
7 Users
I've been looking for something for longish, comfy on-road rides. Not needing multi-day tourer carrying or gravel offroading capabilities. I'd like steel because I do and I'd like as cheap as possible because I'm tight-fisted and light-walleted. I'd like the option of choosing discs.
So had been thinking the Genesis Equilibrium (less all road than the CdF etc so lighter?), the Sonder Santiago, maybe the steel Ribble. Now the Cotic Escapade has caught my eye.
Anyone got any recommendations among those, or suggestions of others I should add to the list? Can be either frame or full build.
Thanks in advance.
Posted : 20/09/2019 12:19 pm
    Bombtrack audax? If you can get your head around the fact that road plus is a good thing in your situation then it looks the business to me.
Posted : 20/09/2019 12:27 pm
 kilo
Something by Spa Cycles perhaps?
Posted : 20/09/2019 12:47 pm
Condor Fratello Disc, in the spirit of recommending what you ride.
Posted : 20/09/2019 12:49 pm
 Bez
Worth having a think about what you might need it to do, which depends on things like how long "longish" is. For some people that might be six hours in the saddle (or not even that much); for others it might be four times that.
"Comfy" IME/IMO is 90% fit, 5% tyres and 5% fork. So: If you're towards one extreme of the size charts then geometry's a big factor in getting good fit, but if you're in the middle of the bell curve then you'll have more freedom.
And make sure that what you buy will be sufficiently adaptable in terms of tyre size: I'd suggest allowing up to 42mm at least to cover you for rides which aren't purely on tarmacked roads (though going for disc brakes will help you here), even if most of the time you find yourself preferring something smaller. And don't forget to allow additional room for mudguards: you don't want hour after hour being constantly hosed with cold, oily water.
Think about luggage. Long rides often mean carrying more food/clothes/etc than you would want in jersey pockets. You have the options of saddle bags, post packs, rack packs, bar bags and more. Some will work better on different frame sizes, they all have pros and cons in terms of effect on handling and ease of access/removal/etc. And if you're anticipating potentially increasing your luggage requirements then it may be worth considering low gearing options such as a triple.
Also consider lighting, which is impacted by luggage. Many audax-style riders will use dynamo lighting, with a front light mounted on the fork crown (which necessitates a hole in the front of the fork crown and, on smaller frames at least, has implications for bar bags or front racks); and a rear light mounted on the mudguard or a rack (for which of course you need a rack), though you can also mount them on the seatpost (implications for saddle bags, rack packs and post packs; again more so in smaller sizes).
There are loads of great bikes around, but the devil's in the details.
Posted : 20/09/2019 1:18 pm
I’d seriously consider titanium if budget allows. I certainly wouldn’t be thinking Genesis low end. Heavy steel and slow handling will suck the joy out of rising. Light and slow handling is a lot nicer over distance. Heavier and faster handling is ok too. Spa Cycles are very good.
Posted : 21/09/2019 10:48 am
I've done a few Audaxes on 3 different bike (Ritchey Logic with 105 which weighs about 9kg, Kona Paddywagon with singlespeed which weighs about 10kg and Croix de fer 10 which weighs about 12kg but feels like more) and for me my Ritchey Logic Road bike was by far the best. They're not cheap but the new one does take up to 30mm tyres, mine rides very smooth on 25mm tubeless road tyres and I ride on pretty rough road in Scotland. But people I've seen on Audaxes are almost riding every type of bike you can think of and they all seem very jolly. If I have the money though I'd be looking at titanium too with plenty of tyre clearance.
Posted : 22/09/2019 7:49 am
