What size square ta...
[Closed] What size square taper BB for 1x9 inbred?
9 Users
Hopeless at this kind of thing, any ideas?
Also, can you use any length cage rear mech for 1x9?
Thanks
Posted : 26/03/2014 8:52 am
IIRC 113mm axle length is for correct chainline for middle ring. You may wish to go for outer mounted single ring in which case you need a shorter axle.
Cage is dependent mainly on cassette range. Short cage I believe wont like more than 11-28T so depends on your block.
Posted : 26/03/2014 9:00 am
 nuke
I tend to use 118mm on my Inbred/Scandal for a bit more chainring clearance as its pretty minimal and I prefer to use a 36t inner and 26t granny but, as stoner says, it depends where you mount the single ring
Posted : 26/03/2014 9:03 am
It depend on your cranks a bit. Are the doubles or triples? Probably anything between 115 and 127mm should be fine.
A short cage rear mech should work fine with most cassettes on a 1 x 9 (i run a 32 x 11/32 with a short sram mech and its fine). You might struggle if it a cassette bigger than 34 though.
Posted : 26/03/2014 9:06 am
^This, +/- a few mm if you want to mess with the chainline.
Posted : 26/03/2014 9:12 am
 Yak
113x68 is standard so will be fine for 32t in the middle ring position.
Adjust from there if needed.
Posted : 26/03/2014 9:59 am
There is no "standard" bottom bracket. It's a 68 mm shell, but the axle length will depend entirely on your cranks. I have two singlespeeds, one needs a 108mm , the other a 125mm as they are different cranks.
Anyone who tells you an axle length without knowing which crank you are using is just guessing.
What cranks are you using?
Posted : 26/03/2014 3:00 pm
As above, the cranks determine what length axle you need. It is worth noting though that inbreds have fairly wide chainstays and it can be worth having a slightly wider one that is theoretically correct to get more clearance to avoid chainsuck eating the stays...
113mm is about as close as you'll get to a 'default' option based on averages but you'd really need to check against your cranks.
Posted : 26/03/2014 3:06 pm
Thanks for the replies, cranks are Truvativ Hussefelt
Posted : 28/03/2014 8:22 am
 nbt
it's 68mm shell. I've used 113 in the past but am running a 118 in my scandal at the moment and it seems fine
Posted : 28/03/2014 8:29 am
