Hi
My shock bushing is not pretty loose so I think it's time to replace the bushings on both ends of the fox RP2 shock
So I want to replace both the sleave (the tube shaped thing pressed into each end of the shock) and the bushings (4 top hat shaped things pushed into the sleaves from each side)
So can anyone tell me what ones i need and where the best/cheapest place to get these is?
What year?
its a 2010 Spicy...
Body mounts are fox ref: 803-03-011
which are 25.4 x 6mm
Shaft mounts are fox ref: 803-03-007
which are 19.05 x 6mm
Info from [url= http://service.foxracingshox.com/consumers/index.htm ]here[/url] click on "Rear Shock Fit Chart"
standard fox eyelet bushings at 12.7mm (I think)
Don't know the best/cheapest place to get them - TFTuned has my new one at the moment and I got them to do it as part of the PUSH tune.
