what shifter for 2 ...
[Closed] what shifter for 2 chain rings at the front
5 Users
Hi I want to move to 2 chainrings at the front
I've tried my current 3 x shifter and doesnt seem quite right just not "wide enuff"
remuse I need a 2 x shifter will this one do
http://www.chainreactioncycles.com/Models.aspx?ModelID=52300
if not any suggestions
Posted : 16/02/2013 6:06 pm
or do I need to change front mech
Posted : 16/02/2013 6:07 pm
Any should work? Did you adjust the limit screws on the front mech? Are the rings in the right place?
Posted : 16/02/2013 6:09 pm
dunno I have 9 seed at the back
a standard 3 x 9 mech and a 3 x 9 shifter
should I be able to get that combo to work with a 2 seed front chhainring
Posted : 16/02/2013 6:12 pm
Yeah.
Posted : 16/02/2013 6:14 pm
maybe I just need to lay with it some more the front mech just doesnt seem to move enough ie the distance between the 2 ring seems greater than on a 3 ring set. is this right or should it be the same distance.
ok cheers will get back in the garage
ta
Posted : 16/02/2013 6:15 pm
I'm using a SRAM X0 3 speed shifter coupled with a 9speed chain and a 10 speed xt front derailleur.
It's all working flawlessly. The Shifter is in positions 1 and 2, the pull in 2 to 3 is shorter and hence doesn't pull enough cable
Posted : 16/02/2013 6:19 pm
I found a double front derailleur is well worth the investment, but I can make it work perfectly with a triple shifter. There was a thread on recently (look at my profile and threads I've been contributing to and it'll take you to it) - end result being that it seems to work best using the middle and outer shift positions rather than inner and middle.
Posted : 16/02/2013 6:25 pm
ah good idea john will try that ta.
Posted : 16/02/2013 6:34 pm
IIRC from another recent thread, a 3 speed shifter seems to work better in positions 2 & 3 with a dedicated 2 ring chainset, but Ive always found a 3 speed shifter works best in positions 1 & 2 with a 3 ring chainset setup with just two rings ie granny and middle ( the latter is obvious but illustrates the difference)
So depends on whether you are trying to set it up with a modified triple chainset or a proper double.
Posted : 16/02/2013 6:47 pm
