What semi-gnarly fo...
[Closed] What semi-gnarly forks
13 Users
I've put off the idea of a new bike for a while so looking at fork options...
Want 34-36 mm stanctions
150-160 mm travel with travel adjust
Independent low and high speed compression damping
20 mm axle
Straight 1 1/8 steerer
Don't get me started on why the hell 15 mm axels are a necessity for 'trail' forks but I need a straight steerer to work with my angle headset. I'm going to have to take a hit on the weight but this is for my only MTB so don't want silly weight as I have to ride and carry up mountains 🙂
So the options I've seen are
RS Lyrik RC2 or RC2L for travel adjust and lockout
Marzocchi 55's - can get either RC3 or travel adjust
X-fusion don't do straight steerer
Fox - I'm hearing bad things about the 34 especially TALAS models.
What else is there?
Posted : 29/10/2013 8:33 am
 wl
Love my 2010 55 RC3 tis. Wouldn't touch Fox 34s right now. New Pikes getting glowing reviews.
Posted : 29/10/2013 8:38 am
Personally id go new Pikes every time!
Posted : 29/10/2013 8:43 am
 jedi
marzocchi all the way baby!
New pikes are 15 mm and tapered steerer only.
So that's 2 votes for 'go stick your head in acid, loser' and 2 votes for the 'zocchi
Posted : 29/10/2013 8:45 am
given the conditions you've imposed on your search, it has to be a 55...
Posted : 29/10/2013 8:58 am
lyriks. bext fork eva!!!
Love my 34's perfect compromise between a burly 36 and an XC 32.
However I reckon they are all tapered and 15mm.
Posted : 29/10/2013 9:01 am
Yeah.. If I want the option of a 15mm axel then I need at least a new hub and to rebuild the wheel. If I want a tapered steerer then I need a new frame...
So maybe I should get a new frame to go with the new shock and forks, by which point I'd might says well buy a new bike... 😈
Posted : 29/10/2013 9:03 am
or maybe you just need to chill out a bit and not read into peoples' replies so much?
tbh, if i had the money i'd get a 55 RC3ti ahead of all the others anyway, regardless of wheel/frame fitting requirements.
Posted : 29/10/2013 9:08 am
Wouldn't touch the Fox 34's with CTD (or any of the forks with CTD - seems to work ok with shocks though).
Posted : 29/10/2013 9:10 am
new Pikes or Marz 55s
Edit: Just seen axle: lyriks or Marz 55s
I have lyriks they are great forks!
Posted : 29/10/2013 10:58 am
this was a conversation I had a few months ago, want to take a guess how it ended...
Posted : 29/10/2013 11:00 am
I recently replaced a set of 2011 fox 36 talas 160mm forks with some 2013 marzocchi 55 rc3 Ti Evo 2. Only had them a couple of weeks, but have given them a fair amount of hammer over 4 days of lift assisted riding in southern spain.
They are loads better than the fox at smoothing out small bumps, they dont blow through the travel under braking/bigger bumps. I'd definitely recommend them if smoothing out the trail is your number 1 requirement above all else.
In terms of criticisms:-
- They are a little heavier (only 200grams though) than the fox
- the coil spring does not allow loads of spring rate adjustment if you're significantly heaver or lighter than average.
- Despite what the marzocchi website implies, the high and low speed compression is not independently adjustable. You adjust compression damping with a single knob, you increase low speed compression and high speed compression decreases and vice versa. No idea why they've done this, but to be honest it doesnt seem to be a real problem. the performance is excellent, but you cant set high and low speed compression independently.
Posted : 29/10/2013 11:16 am
A straight steerer? What century are you living in Jon? Just buy the new bike. Go on. 🙂
And stop putting pics of the Port Hills on farcebook. 'snot fair. 🙁
[url= http://www.pinkbike.com/news/Magura-TS8-R150-Fork-Tested.html ]Magura TS8 R150[/url]? Not 34s, but very stiff and very lightweight. And you can get a straight steerer 😉
And get a new front hub that will take a 15mm axle.
Posted : 29/10/2013 11:28 am
BOS Deville missing from that list
Posted : 29/10/2013 11:34 am
I have a spare set of TFT sorted Fox RC2, 100-130-160 Talas, with the steerer and axle you are after.... and without the CTD schnizzle.
Used but in good condition, stanchions unmarked....
Posted : 29/10/2013 11:39 am
We looked at the list price of a Mach 6 and went 😯 I could build up a fame with better bits for less, but availability is all over the place for the 650b stuff.
'snot fair. 🙁
sorry 😥
Posted : 29/10/2013 5:47 pm
We looked at the list price of a Mach 6 and went I could build up a fame with better bits for less, but availability is all over the place for the 650b stuff.
I pulled the LTc together for less than a lot of other things 🙂
Posted : 29/10/2013 9:27 pm
