I need a new seatpost for my beast... Because of the angle of the 'seat tube' it needs to be one that allows much more tilt than normal - something like a raceface XY0 for example (which unfortunately I can't find)
Any suggestions other than the really expensive posts? I don't really want anything expensive as TBH, my mantra is only for fun (I basically got it for free).
Needs to be 31.6 and 400+ length, no layback.
[img]
[/img]
(the saddle in the pic works with the current post but has oddly angled rails which allow it to be set flat - other saddles end up pointing at the sky)
Have you tried an i-beam seatpost, they have quite alot of adjustment?
Hope Eternity has a huge range of adjustment - just not sure on the length thing .....
you can get a 27.2 seatpost and a shim, don't forget
USE sumo or Hope post as said above.
Or another post with that type of clamp
Thomson Elite? Defo long and strong enough, not sure about the range of adjustment tho
Or have a look for a Salsa Shaft, that has a fairly unusual clamping set-up
nbt - I'd considered that but I prefer a bigger dia post given the angle and my size - I've bent a few posts in my time which in turn writes off the Sumo as I don't reckon they're all that strong...
Hope's an option but maybe rather expensive.
Clubber, I have an almost new 400mm x 31.6 Race Face XY, not XYO, so does have some layback but you can shuffle the seat forward and the differnce between an XYo and an XY is ~20mm ( I have both, just the XYO is 250mm long)
any use to you?
Hope eternity,use sumo or bontrager.
hope, close to infinite
amedias, drop me a mail.
I have found this too though
http://www.pedalon.co.uk/acatalog/bontrager-race-seatpost.html
mailed you
Clubber, how did you fit a rear disc to your Mantra? I have one of these gathering dust in my parents garage, you've just alerted me to the possibility of resurrecting it as a singlespeed!
KCNC SC Pro Lite has lots of adjustment. I think it's available in that size.
thorpy - mine came with a Hope C2 with the right adaptor but you can bodge one otherwise with an A2Z adaptor I believe. Like this:
http://www.amazon.com/A2Z-AD-PMR-Brake-Adaptor-Hayes/dp/B003QRB7F6
(You can get them in the UK, just the first link I found)
Thanks for that clubber, so yours has a hayes 22mm mount? Don't think mine has that (will have to check). Maybe its an older model.
Yes, it has the 22mm mount.
