What sealent have you found most effective in your tubeless set up?
I've had a few punctures recently that should of self sealed recently but stans has failed
Anyone? Is there something better than stans?
Stans is it, and it works if you use enough of it. Problem aside from not enough or letting the stuff dry out, is some holes are just too big. Typically sidewall tears won't seal well.
Anchovies for holes in the top that won't seal, boot patches inside for sidewall tears, or get reinforced sidewall tyres.
Only had a couple that won't seal, but can see loads of holes where the stuff has worked. Plus impossible to get pinch flats tubeless so worth it to me as that's the majority.
