as above, what’s the best nowadays for an mtb tyre , portable, not home type, thanks
Topeak Mountain/Turbo Morph. It's a fair bit bigger than most compact pumps (though similar size to old style frame-mounted ones). It will inflate a tyre with a few strokes, no furious pumping needed.
I use a lezyne one but i agree that any larger volume - yet still compact ish- pump with a foot stand will do. its not like we dont have space in our packs for one.
https://www.merlincycles.com/lezyne-micro-floor-drive-hp-45095.html
MTB morph or a one of the cheaper clones of it (M-part maxair 2 sport)
I use a Mountain Morph for the fat bike and a Mini Morph with the hardtail.
I've an aversion to Lezyne (and other) pumps with screw-on heads as they've an annoying habit of extracting the valve core on tubeless valves when you take the pump off. Yes I could lock down the valve core but I shouldn't have to and when you are out in the middle of nowhere your tools should work with you not against you. (Sorry, end of rant)
I’ve an aversion to Lezyne (and other) pumps with screw-on heads as they’ve an annoying habit of extracting the valve core on tubeless valves when you take the pump off
it comes with a push on adaptor and yes i have had that happen - never with my tubeless one as they are stuck with gum 😉
Truflo 2-stage kicks the arse out of the Mountain Morph. Though it does have a screw-on, it's not like the Lezyne one- it'll only remove the valve core if you've left it loose.
Mini Morph user here, had 100psi in the road bike tyre before with it.
