What oil to Mavic h...
[Closed] What oil to Mavic hub?
5 Users
 mgig
Hi,
In Mavic manual it says to use mineral oil Mavic 996 136 01 in Crossmax ST hub.
Can't find it anywhere - what else could be used?
Thanks
M
Posted : 10/05/2014 1:20 pm
 jimw
I have used Shimano brake fluid with no problems for the past 3 years. Don't use DOT fluid though!
Posted : 10/05/2014 1:25 pm
 mgig
I have Magura red blood mineral oil for brakes - I guess this should be ok?
Posted : 10/05/2014 1:53 pm
Assuming the hub is similar to the Mavic road hubs then I use 3 in 1 oil. Any light oil will do, you don't want anything thick (especially not grease) because this will cause the freewheel to drag.
Posted : 10/05/2014 3:04 pm
Asked the same question a few weeks ago. My lbs uses finish line wet, other places use Shimano mineral.
Posted : 10/05/2014 3:18 pm
I just got the mavic one, if you are in Berks more than welcome to come and take some. If not then I ordered mine from here and they still have stock:
http://www.pedalon.co.uk/acatalog/mavic-fts-freehub-oil.html
Posted : 10/05/2014 3:33 pm
