what oil for lowers
[Closed] what oil for lowers
6 Users
what oil should i use when serviceing the lowers on fox floats? mojo want £15 for suspension fluid. they only sell it in 1 litre and belive it or not 1 of the guys behind the counter said to just leave it dont worry about adding the 5ml in each leg.
Posted : 22/02/2010 9:28 am
That's because they want you to wreck your forks and spend money on repairs or new ones. Stupidiest advice I've heard in a long time. If anything, put MORE in!
Would you leave out your car engine oil?
No?
It's the same principal - Lubricating plain bearings!!!!
Posted : 22/02/2010 9:33 am
how old is you'r car?
RE Bullet had a plain (white metal?) big end and they first appeared on cave paintings IIRC
Even my midget runs on needle bearings.
:p
but yes, more is better, within reason (you start to lose travel and blow seals if you go too far over the recomended level.
Posted : 22/02/2010 9:36 am
:p
Well, the only engine I've had apart had plain big end bearings. I thought all cars still did? Happy to be prooved wrong though and it was only an example! 🙂
Posted : 22/02/2010 9:44 am
 cp
go on the fox website, tech docs area and figure out what weight of oil you need. go to motorbike shop and buy for half the price or less..
Posted : 22/02/2010 9:46 am
I was just about to say exactly what CP said. That's what I do myself. 🙂
Posted : 22/02/2010 9:47 am
ok thanks guys
Posted : 22/02/2010 10:08 am
Used to blend my own mix of Auto transmission fluid and motor oil* for suspension use back in my motorbike days.
It's easy to do relative viscosity tests - get a plastic measuring jar, poke a hole through the bottom and put your mixture in. Time how long it takes for 100ml to run through. Use that as your baseline and fiddle with your mixture.
I would try different mixtures in the suspension until I got the right feel. This was all necessary because suspension was pretty primitive back then.
It depends what's cheaper - your time or a bottle of the recommended fluid. 🙂
BTW its better if you try to ensure the temperature is the same. I used to do 2 tests, one at 20 degrees and the other at 80.
*pick one that doesn't foam up - I'm not current with that sort of thing now, so I don't know what's good.
Posted : 22/02/2010 12:26 pm
Just spend the 15 quid, or experiment with your own brew and potentially break your expensive forks.
And if you think £15 for a litre of oil is steep then you haven't ordered your crush washers yet have you.. 😳
Posted : 22/02/2010 1:11 pm
