What negative rise ...
[Closed] What negative rise stem?
10 Users
After 80mm stem for new (29er) build. I [b]think[/b] I want a negative rise stem to lower the front a bit; apart from the -10 EA70, can anyone recommend any other options? Is there a -15 option?
Posted : 18/12/2013 7:21 pm
Bonty do a -17
http://bontrager.com/model/11291
Posted : 18/12/2013 7:22 pm
KCNC do a -17 one in both 70 and 80mm
http://www.xcracer.com/shop/viewproduct.php?productid=314
Oh and of course what him below just said vvv
Posted : 18/12/2013 7:25 pm
Any positive one turned upside-down 🙂
Posted : 18/12/2013 7:26 pm
^ just what I was thinking.
Posted : 18/12/2013 8:26 pm
OK, what are the 10 deg rise option, then? 😛
Posted : 18/12/2013 8:32 pm
Negative Rise - you mean a drop i assume?
Posted : 18/12/2013 8:33 pm
Yes, but why use one syllable where several will do (or alternatively I'm post on call and a bit addled as a result of sleep disruption)?
Posted : 18/12/2013 8:39 pm
My Smica one conveniently has a double-sided logo so it even reads properly upside-down 🙂 as it is on my hybrid.
Posted : 18/12/2013 8:41 pm
Many do (like the Bonty one I linked to)
Posted : 18/12/2013 8:42 pm
3T for me, basic one is 6 degrees and the nicer ones also have a 17 degree option
Posted : 18/12/2013 8:45 pm
Pro Koryak - any good?
Posted : 19/12/2013 8:30 pm
ratherbeintobago - Member
The Thomson X4 10 degree stems are reversible with graphics that read both ways.
Posted : 19/12/2013 8:32 pm
Sadly, the Thomson 80mm 10deg stem isn't available yet.
Posted : 19/12/2013 8:33 pm
Ah, sorry about that didn't realise.
Just out of interest, if you have a look at this [url= http://yojimg.net/bike/web_tools/stem.php ]link[/url] you can mess around with different stem lengths and rise and see how it will affect your setup.
I've found it really handy.
Edit - [url= http://www.aspirevelotech.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=AVT&Product_Code=V305-SM37268&Category_Code=TH-X4-080 ]Aspire Velotech[/url] are listing the 80mm 10 degree stem, so it might not be too far off?
Posted : 19/12/2013 8:39 pm
That stem calc tool is great. Very handy.
Posted : 19/12/2013 8:49 pm
Edit - Aspire Velotech are listing the 80mm 10 degree stem, so it might not be too far off?
Maybe; I'll keep an eye on that.
The stem calc tool is very good - thanks.
Posted : 19/12/2013 9:08 pm
mtbfix - Member
I've used that stem calc tool quite a bit, especially before committing to buying a new stem. Takes the guess work and expense out of it.
Posted : 19/12/2013 9:12 pm
Ritchey c260?
Posted : 19/12/2013 9:42 pm
Ritchey c260?
Isn't that only a 6 deg offset? Also, I've heard that some bars don't get on with the Ritchey clamp (hence C220 trail stem).
Posted : 19/12/2013 9:52 pm
