So.....let's assume money not an issue.
If you had to build a disc rear wheel which should ultimately provide reliability, what hub would it be?
XT?
Hope?
Tune?
Chris King?
Royce?
King
money no object?
http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=300&Name=Goldtec+Pro+Competition+Rear+Hub+-+Rims+-+Wheel+Build+Options
otherwise
http://superstar.tibolts.co.uk/product_info.php?cPath=31&products_id=364
which is on special at the moment
King every time they just do what they should for ever and a day.
Phil Wood
I know nothing about them but they are shiny and expensive so they must be good..right
DT Swiss 240s
Except they don't. And they need god knows how many expensive tools to adjust and repair them.
DT Swiss 240s for me, after I gave up on Hope(less) hubs.
DT Swiss 180 carbon ceramic
Weight: 202 g
[img] http://www.dtswiss.com/CmsPages/GetFile.aspx?guid=d627a527-a24c-4ff2-9263-6acc2af2db83 [/img]
I like Hope, but they're not really 'money no object',
I've got King on my bikes. The oldest two sets are well over a decade old. In the four sets I've had, (currently 3) I've only snapped one rear axle. That's the only parts I've used.
Edit: had Royce. Beautiful, the prettiest hub and a lovely loud almost campag like sound. But unreliable, went through bearings in months not years and I have a mate who cracked 3 hub shells with only light use
DT 240 or 180/190 pending on
What poddy said
It's funny how people who actually fix bikes for a living (or have done) always end up recommending DT Swiss over and above everything else... 😉
Really? The only two DT Swiss hub owners I've met have had to replace the freehub. One person several times before giving up entirely.
Chris King for me. They're just so luxurious compared to Hope, and the buzz is addictive. It's like the bike equivalent of a V8 burble.
Peter thats bollox mate they run for ever !they do one dead posh tool that costs loads but you don't actually need the thing to service the hub anyway .
Two years on a set and actually haven't had to do much at all to them.
No it's not and no they don't. Some do. But then so do some Deores.
More discussion here
http://singletrackmag.com/forum/topic/chris-king-hubs-over-priced-or-ture-quality
Have to agree with the comments about DT 240's, really great hubs and lighter than King if that matters.
If I was buying NEW (I usually buy used) and money was no object I'd get XTR, no question about it.
I've got a lovely set of pink Chris King disc hubs that I'm about to sell (currently built up with XC717 rims) if anyone's interested. 🙂
Very little use, good as new.
Tune! Have a set on my road bike. Recently cleaned and service the rear hub. Bearings still smooth and buttery after 7 years and well over 15000kms. Consider I weigh in at 106kg I can highly recommend the hubs.
I can't be arsed to argue Peter that thread you posted is fairly split really so I suppose its just the same old Internet debate, yes they are no they aren't .
Have 2 sets of BOR hubs,are very similar to Tune. Very light and well made.
I have kings on all my bikes, have done for years, the only special tools I've ever needed are a pair of Allen keys to get into them and relube them. They are all still good as new, covered a lot of miles and needed very little adjustment except for the little cone adjuster thing on the side which turns by hand. I've never had any call to replace the bearing in them and the bearings have always been superb.
That said, I'm not sure they are the be all and end all, i just prefer them. Phil woods are really good and I'd have no problem with Dt's either. Royce look amazing too, i'd love to try some but I'm just not convinced about them. As far as functionality goes, something like an XT or Ultegra are great for the price
Rohloff~ reliability x3 (or cubed)
i) damned reliable hub
ii) eliminate drivetrain wear and pay for itself in the process
iii) dishless build makes for a stronger wheel too
To add to the mix, the only time I've ever seen a king, it had more play than a pac man arcade cabinet.
Check the price of a replacement DT190 freehub before buying the actual hub. If memory serves the part alone costs more than a pair of Hopes.
DT240 - available in 6 bolt though axle choice a bit restrictive once made.
Im selling a pair of BNIB kings should you go that route 🙂
I'd stick with my DTs tbh, light enough, reliable, (mostly) easy to spanner, easy to get parts for... Kings are nice but they're not a company I want to give money to frankly.
Profile Elite Mtb Hub
It's got to be a Rohloff, really - not some bling thing that takes a normal cassette. That's not ultimate reliability.
I alway had in my mind that I9 hubs were the nuts, but seeing as no one mentioned them I guess not!
Reliability?
Dump the disk.
Sturmey-Archer drum brake hub. Used on industrial bikes the world round.
got a DT240 here with proper wibbly bearings or freehub that need replacing. to do it myself I'll need a tool and I don't feel confident about doing it either. to talk to the lbs about it, they just talk about the mechanic hating them and it being more expensive than buying a new hub or prefering world war 3. perhaps, if you know of stuff about hubs and have the tools a DT240 is great! and a runner forever? But as a hub fiddling pleb, it's a less hassle to buy a deore hub and replace it than sort the 240. I can't just pop the bearings in and out can I? or can you just "replace" the freehub?
For a winner of best hub.. these questions wouldn't occur
dmr revolver if they still do them. Love mine. Keep the change.
I run goldtec Draco hubs. Can't fault them at all.
Can't knock King although I wouldn't buy one now, way too expensive.
I bought my rear for £240 new on offer about four years ago, from Stiff.
I also got the expensive tool eventually.
When I wanted to bolt my axel up, King did the parts (fun bolts), easy change
When I almost bought a frame that was 142mm x12mm thru axel, King did the parts, ok they were £80 but at least I could have still used my hub! I like the way it can grow with bike design changes, so far anyway.
I've "serviced" it once. It didn't need it, once the inside was open, it was mint, after 3 years and 2 Alp trips.
The engagement is nice and swift, the noise is nice, although louder would be better.
I posted on here that I liked the hub but the RRP (then about £340) it wasn't worth it. I still feel that way. If you find a reduced one, maybe it's worth it.
As far as the engineering goes, I can't fault it.
Surly Singlespeed hubs here. Have been on a few years. Not had to open them up for any reason. Running a White Industries freewheel. I think they weigh more than the rest of the bike though.
I dont believe they fall in to the [i]money no object[/i] category though. 🙂
I recall listening to the audio call-ins from the Tour Divide this year, & there was one pretty peed off chap who had to drop out of the race due to a King hub failing. 😕
I'd probably spec XTR if money was actually no object, but I've promised myself a wheelset with red hubs next time. 🙂
Not quite sure why people are posting all these super bling lightweight hubs like Tune and DT 190 if reliability is the primary requirement. For ultimate longevity with no concern as to cost I would go with Phil Wood. I have some which are heading on for 10 years old and I've not had to touch them once. In that time I've been through countless sets of Hope bearings, a couple of DT freehubs, and a fully exploded Tune freehub (which they replaced no quibbles I have to say). XTR would also be a very good option but I believe they are centrelock only, which would put me off a little, purely for reasons of disc interchangeability with everything else I've got, nothing wrong with centrelock in itself.
Rohloff. No question about it.
Royce
XT. Run into ground, replace.
Only bad thing about XT, is they don't come in colours if thats your thing
Hadley? Love mine on flow rims, prefer them to the dt 240's on my other bike.
JoeG, what's the point in a front hub with 3deg engagement? 😆
Several of something very good rather than one of the most expensive?
Mine has a ti freehub being the SS version so no issues there, I also believe they changed the ali freehub on the other Tunehubs to a different design.
You will get stories of failures on all hubs as people are more likely to grip than comment about no issues
Kevevs - Membergot a DT240 here with proper wibbly bearings or freehub that need replacing. to do it myself I'll need a tool and I don't feel confident about doing it either. to talk to the lbs about it, they just talk about the mechanic hating them and it being more expensive than buying a new hub or prefering world war 3. perhaps, if you know of stuff about hubs and have the tools a DT240 is great
Not being funny, but your shop sucks [i]balls. [/i]
More helpfully- only the very centre bearing needs a special tool to access, everything else is just standard whack out, whack in including all the freehub bearings- it's a 5 minute job to change those. All standard bearings too.
The one that does need the tool lasts a very long time as it's so well protected, but when it does need done the tool's not all that expensive. (£25 or thereabouts if I remember rightly). But if this is the first time you've done the bearings, then chances are it's fine, they seem to need replaced about 1 time out of 3.
The freehubs are pretty damn expensive mind but then you shouldn't really need to replace one of those.
I'm a Dt fan but have the ring drive tool to change the inner bearin with
Does last ages though
The 190 is just a silly price
For the money stans hubs seem very good and lots of axle options
Money no object I'd still buy King, had a few over the years and had very few problems with them, almost fit and forget.
What I always had trouble with Shimano XT and XTR is the freehub mechanism not working when it was freezing out. No amount of GT85/grease/oil etc seemed to make any difference and although pissing on it works you eventually run out of piss on long rides. I know Hope are not considered bling and have their issues but I find mine reliable and so easy to work on that I'll forgive the few issues I've had.
I consider DT/King a step up from Hope but I will stick with Hope so I can have two hubs/wheels for the price of one... having a spare set of near identical wheel (used on another bike) is a bigger boon than having one pair of ultra bling wheels IMHO.
I'd love to try the Kappius hub if money truly was no object.
Another recommendation for Rohloff.
I had the first one in 2003, so far it's had an annual oil change, 2 sets of new cables, 1 set of seals, 1 16t sprocket.
Bomb proof but not cheap 😀
King fan here. I've killed pretty much everything else but these just keep going.
GB
Never really had much problem with hubs, apart from shimanos, one bent axle & two dead freehubs. Replacements are cheap though.
So, I'd probably buy Hopes and keep the change. Or splurge out on a Ti freehub.
TBH I'm not convinced about the logic of spanking £400 on a King hub. I've had (rebranded) hubs from Chosen, Novatec & Chin Haur - all have been perfectly reliable IME.
I wonder how much hub longevity comes down to the frame? Dropout alignment and swing arm/chain stay design for instance. Never mind usage and rider.
King for me, but as has been said, try and get a good condition second hand one.
Really like the 240s as it's such an ingeniously simple design, so I'd just stick with that (or go with the 180 version if I had money to burn)
Not sure what people are talking about with "replacing DT freehub" here....the "freehub" is not part of the hub at all, it's just two opposing discs (about the size of pound coins) that are pushed together with springs. If pressed, I reckon I could replace them both in under a minute with no tools at all.
Centre bearing replacement does need an expensive proprietary tool though...
I think they meant the freehub body- which is pretty dang expensive, but not a consumable/wear item so it should never matter.
only hub I've known that to be necessary on was....King.
Chris King.
They require a little more setup than most, but use less parts in a lifetime than EVERYTHING else.
I've got 5 sets of Kings, 2 sets of DTs, 1set of I9s, 1 set of XTRs, 2 sets of White Industries, 1set of Deore. 2x Alfines (8 and 11)
The Kings have needed nothing in a combined life of 25 years and almost 20k miles. The DTs have needed 3 sets of bearings between them at a cost of ~ £90 in the past 3 years, The I9s seem to lose spoke tension all the time. The front XTR hub died in a year, despite being serviced at 6 months...pitted cup surface. The WI's are only a year old but the MTB SS wheels are on thir second set of bearings. The Deore front was ruined in 2500 miles. The Alfine 8 is perfect, and the 11s problems are myriad.
Just my opinion/experience.
I think Profile for me, reminds me of my bmx days
Maintenance makes a huge difference to the life of a moving part.
If the quality is halfway decent, and you keep the muck out and the lubricants in, then any hub should last a very long time.
For example, the hubs on my 1932 Sunbeam are original and when I looked there is very light pitting but the surfaces can be reconditioned, so another 81 years is possible. 🙂
Ditto on King needing maintenance but not replacement parts.
Maintenance needed = free and prevents failure of parts
Parts needed = expensive and tend to mean failure of parts has occurred = ride ruined
I know which I'd rather have.
GB
I've had a set of Industry 9 hubs that I was less than impressed with. Did a muddy race in Essex when they were brand new and it all but wrecked them. Hope's are good but pretty heavy. Kings are lovely but the noise gets on my nerves after a while.
I like my Tunes (I have the Ti free hub which is much better than the alloy version) and I've never had problems. Although I think I'm the exception as most have..
Because that wasn't a primary requirement? 😕
I was very underwhelmed by my Kings frankly, heavy, draggy, and needing lots of maintanence. I know a lot of people find them great though.
DT 180 or Extralite SPDs for me, although the price on the freehub body for a 180 is ridiculous! [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=35017 ]Just £300 retail[/url].
I have some extralight road wheels Useing the older hub and the silly plastic bush is worn but going to have to see how long it takes to get a new one from Italy
But they have done many miles and been fine , mine do drag a little when freewheeling though
[url= http://www.paulcomp.com/diskrhub.html ]Paul RHUB[/url] looks nice, with I9 innards.
Interesting article about Paul himself in Privateer #16, too (which inevitably arrived 48h before ST83, so I've barely had a chance to read either :-/)
P20 - MemberJoeG, what's the point in a front hub with 3deg engagement?
Faster engagement! Some fatbike owners run rear hubs front and rear, the front is an emergency spare in case the freewheel freezes up. They just switch wheels and roll on. The one below has a single cog on the front instead of a full cassette: 8) 8) 8)
[img]
[/img]
That is brilliant. Never seen that before.
Wonder why forks aren't made the same spacing as the frames so all mtbr's could do this?
[url= http://www.bikerumor.com/2013/01/04/found-alchemist-310g-carbon-clincher-29er-rims-lightweight-magnetic-hubs-more/ ]Magnetic hubs from Italy on Bike Rumour[/url]
DT240 here, wouldn't trust the 180 personally.
DT240s
