What makes one bike...
[Closed] What makes one bike faster than another?
44 Users
OK, I think we can all agree that the number one factor in how fast you go on a bike is you. After that I'm guessing that we'd all agree that total weight is most important. But what comes next?
In my ongoing mission to compare and contrast my old (2006) Five and my new (2012) Trance I've started to look at times. I've loaded a load of rides into Strava and defined a number of segments (mostly, but not all, climbs). The nice thing about this is that I didn't know at the time that these segments were being timed, which should remove some of the operator bias that always plagues these tests. What I'm finding is that my best time on the Trance is consistently faster than my best time on the Five. A one-sample t-test on the percentage difference give p<0.01, which for the non-stats-geeks (i.e. you normal folk) means that we can be 99% confident that the difference is real and not just a fluke. The average difference in speed is around 10% (varying from 5% to 18% for the 8 segments I've analysed so far).
Now, I know that the total weight of both bikes is pretty much the same (both are almost bang on 30lb all up weight). I also used the same wheels (and pedals) on both bikes. In fact, for most rides, the bars and stem were the same too).
So, the rider was the same, the total weight was the same, the wheel weight was the same, but there is still a 10% difference to account for. What else could cause that difference?
Posted : 04/03/2013 12:11 pm
Pixie dust.
And red paint.
Posted : 04/03/2013 12:12 pm
Colour coordinated components and a full face helmet.
Posted : 04/03/2013 12:14 pm
Relative turd mass prior to experimental procedure?
you are fitter. HTH.
Posted : 04/03/2013 12:16 pm
Same tyres too? Tyres and tyre pressure can make a big difference. Fit/geometry is critical too. If the bike fits you well you'll be in a more efficient riding position. I took my new bike out at the weekend and just sliding the saddle back by 10mm or so made a MASSIVE different to comfort and hence my efficiency. Small things for small gains all add up. It's the entire British Cycling strategy 🙂
Posted : 04/03/2013 12:18 pm
Surely that just come's under 'rider'?
Dirt used to do group tests with timed runs. Interestingly downhill the bikes (anything from 5-6" trail bikes to DH bikes) were almost always within seconds of each other (on a 2min DH track), but uphill they either managed it in the same time as the reference hardtail or failed miserably (so the times for example would be 5:00, 5:00, 5:01, 5:02, 10:30) with not many inbetween.
I'd say you're just better than you were 6 years ago, and therefore the 6 year newer bike is faster.
 D0NK
unless you're riding the 5 and the trance back to back, I'd have thought the chances are you're fitter and more skilled - unless you've covered that elsewhere.
edit
maybe that too, was just thinking the other day, I wonder how many 29er/650b/rigid/FS/whatever converts have actually just by fluke have ended up with a bike that fits them 100% perfectly and [b]that's[/b] the difference, not the wheel size or other niche.
Posted : 04/03/2013 12:23 pm
 wors
Does it matter? I'd have thought fun was the major factor comparing those 2 bikes?
Posted : 04/03/2013 12:29 pm
tyres
are you riding with more aerodynamic kit now?
Posted : 04/03/2013 12:30 pm
White braided brake hoses make any bike faster, FACT
Posted : 04/03/2013 12:31 pm
Press fit bottom bracket and OverDrive 2 steerer tube.
Posted : 04/03/2013 12:46 pm
Sorry, I wasn't very clear there. Although the Five is an old model I only got it recently and all the rides were done over the past year.
My first though was some kind of bias to do with my fitness or weather conditions, but even selecting rides that were done on the same route within a week of each other there still seems to be a consistent advantage for the Giant.
Of course, speed is only one factor and may not even be that important to some people, but I'm surprised by the size and consistency of the difference.
Fit might be part of the difference. The Trance is a large (20")and the Five a medium (18") and the Trance does seem to fit me better. I'm surprised that makes such a big difference though.
Stiffness is something that I thought might be to blame too. The rear of the Trance feels very solid whereas just riding the Five down a trail it feels looser. What I need now is a new Five with a (stiffer) maxle rear end for comparison 🙂
Posted : 04/03/2013 12:49 pm
It's how efficient the maestro design is. It blows the five design away and as efficient as the five feels, it's not a patch on the maestro system. Not to mention how torsionally stiffer it is through the entire length of the frame.
Maestro giants are rocketships. They remind me of my Turner with DW. A different league.
Posted : 04/03/2013 12:55 pm
If you really want to get into it you have to consider things like spoke tension, bearing wear, frame design (flex and stress points specifically), and so on and so forth.
Posted : 04/03/2013 12:57 pm
Good inch and a half extra length in the Trance top tube, I'd definitely say it would be a factor. Sizable difference though!
Maybe it's because you care too much about figures and time than riding the bike 😉
The big question should be... which is more fun?
Posted : 04/03/2013 12:58 pm
Are you using the same forks or do they have different amounts of travel?
I have a 2005 Five and would say that most new FS bikes would be better going up hill, unless i drop the front end travel to 120mmish. I'm talking long slog fire road type stuff here, technical stuff I think it's decent but the Five is not a bike for going up hills fast IMO.
Conditions would be a major factor for me as well.
Posted : 04/03/2013 12:59 pm
Given the bulk of riders top 10 in races like Megavalanche are on single pivots they must be hella fast then. Imagine how fast they'd go with Maestro! 🙄
They're not though are they, otherwise in a race situation nothing else would get a look in.
Posted : 04/03/2013 1:01 pm
You nailed it in one ;O)
Posted : 04/03/2013 1:02 pm
Yes, it could be the forks. Fox 125mm on the Trance vs 150mm Revs on the Five(actually 120/150 dual position, but I rarely bother to knock them down to be honest). Not sure I understand why though. Seat angle is pretty similar, so my position relative to the cranks is the same. Most of the climbs I've looked at aren't steep enough for the front to be lifting, more steady drags and often done with both forks locked out.
Conditions could be a factor, but I've done quite a few back to back (a few days apart) rides, to try and limit the effect of trail conditions.
To be honest, I expected the variability to be so high that I wouldn't see anything statistically significant, so was surprised to see such a clear and significant different. It could still be something unrelated to the bike though.
To those that say it doesn't matter and I should stop worrying about the numbers, that's fine. Nobody says you have to care how fast your bike is. I'm not even sure how important it is to me, but I would like to try and understand what might have caused the difference. At the end of the day, a more efficient bike allows me to go further for the same effort, which usually equals more fun for me.
Posted : 04/03/2013 1:18 pm
If you still have the 5 try a back to back test with the same tyres and pressures
Posted : 04/03/2013 1:43 pm
It won't be dead accurate,toasty but a hell of a lot more accurate than what you posted above. :OD
Megavalanche top 13 2012
Remy Absalon (not) on a single pivot ~ http://world.endurotribe.com/2012/08/remy-absalon-wins-2012-megavalanche-in-lalpe-dhuez/#toparticle
nicolas Lau - a cube stereo with a horst link
Dan Atherton - another single pivot? no.His GT.
Greg Doucende - Trek,not a single pivot.
BAILLY MAITRE Francois - a single pivot Scott? No.
Jerome Clementz - Cannondale , not a single pivot. http://www.wtb.com/catching-up-with-jerome-clementz/
Olivier Giordanengo - yeti sb66? If you could call it a single pivot.
Lucan Anrig - santa cruz (and it wasn't a Chameleon ;O)
Nicolas Quere - Commencal - not on a single pivot for mega
Gustav Wildhaber - Santa cruz (nomad possibly)
Karim Amour - kona.
Franck Parolin - Giant (and it wasn't a tcr composite ;O))
Cameron Cole - Lapierre
Posted : 04/03/2013 1:46 pm
You're trying harder on a new bike ( that subconsciously you want to be faster to reinforce your purchase decision) that fits you better.
Stop worrying about it
Posted : 04/03/2013 1:48 pm
[b][u]Steve77[/u][/b]If you still have the 5 try a back to back test with the same tyres and pressures
The rides I'm comparing were all done with the same wheels, tyres, etc and in most cases it was the same trail ridden on the two bikes a few days apart. I just swapped the wheels over from one bike to the other to try and keep things as consistent as possible.
Posted : 04/03/2013 1:51 pm
martinxyz - Member
Karim Amour - kona.
Ohhhhhh dear
Commencal - SP
trek - SP
Cannondale - SP
Yeti - definately not a single pivot
Kona - SP (unless it was a magic link?)
Posted : 04/03/2013 1:54 pm
As OP says you and total weight are the 2 biggest variables.
After wheel/ tyre combo and pressure I would say drive train resistance would come next. A small amount of pedaling power is lost to friction in the drive train and the smoothness of the bearings.
Sounds like a fun project, I've got no head for stats!
I went from a trance frame to an ASR5 (mostly same components) and I couldn't believe how much faster it was. The geometry is very different between the bikes which I think must be the main thing - the ASR5 encourages you to throw it into corners, and has a much lighter, stiffer rear end, just encourages you to go faster. The trance was a good bike but much more 'safe' a ride than the yeti.
Posted : 04/03/2013 1:57 pm
[b][u]nickc[/b][/u]You're trying harder on a new bike ( that subconsciously you want to be faster to reinforce your purchase decision) that fits you better.
Normally I'd be with you on that one. Operator bias plays a huge part in these tests and (in my mind) pretty much invalidates any bike comparison I see written online (including those 29 vs 26v s 27.5 ones). However, I bought the Five (from ebay) after the Trance and if I'm honest I really wanted the Five to be better. I prefer pretty much everything about the Five, right down to the frame colour. But even I'd have to admit that (based on this very limited sample of two specific bikes) the Trance is consistently faster.
OK then 🙂
Posted : 04/03/2013 1:58 pm
Rover, there's a few lightweight bikes out there with poor design that will feel slower than a bike with a well thought out design/spot on pivot placement that can be around 3 pounds heavier than the other bike, but still climb quicker.
I'm not talking about the Five when I say that, I had others in mind.
Posted : 04/03/2013 1:59 pm
No, we don't - or at least only to the extent that that already comes under "you", bike weight certainly isn't the next most important thing. For a start using your evidence, there's no way the difference in weight between your two bikes makes 10% difference in speed. Though I'd have also suggested that tyres make more difference than bike weight.
Posted : 04/03/2013 2:02 pm
Hehe at the Mega thing 🙂 Quite a few single pivots in there, you see a lot on the bigger beefier models. If you'd looked at 2011 results there were even a couple of Orange in there.
[url= http://www.megavalanche.com/ckfinder/userfiles/files/resultats%20mega/MEGA%202011%20ALL%20RESULTS.pdf ]http://www.megavalanche.com/ckfinder/userfiles/files/resultats%20mega/MEGA%202011%20ALL%20RESULTS.pdf[/url]
2x Orange and the Commencal top ten at very least. Most of the rest being 4 bars, which are plusher than single pivot if anything. Completely the opposite direction to the VPP/Maestro setup.
Not that it makes a difference anyway 🙂 Which was pretty much my original point.
Posted : 04/03/2013 2:03 pm
What about go faster stripes?
Posted : 04/03/2013 2:10 pm
29ers are faster. Obviously.
Posted : 04/03/2013 2:12 pm
OK, I guess we don't all agree that weight is the second most important factor 🙂
Total weight (you plus bike) is pretty simple to understand though. Work done in climbing a hill is weight times height, so time taken to do the climb is weight times height divided by the power that you produce i.e. speed up a hill is directly proportional to weight and if you double the (total) weight and put out the same power it should take you twice as long to get up the hill.
But I'll concede that letting all the air out of your tyres might have a bigger effect 🙂
It's all irrelevant in this case as we are talking about the same weight and same wheels under the same rider.
 D0NK
Commencal - SP
trek - SP
Cannondale - SP
don't most of those have a single pivot between the frame and the back wheel but a multitude thereof elsewhere? Might not be 4bar, vpp or DW but still (the possibility of being) a fair bit more sophisticated than the orange [b]single[/b] single pivot?
(I do own an [b]s[/b]sp and very nice it is too, but clever it is not)
Posted : 04/03/2013 2:19 pm
Well, at the risk of being controversial; I went along with a mate on a Five test ride, and everyone agreed it was an utterly terrible bike in every situation.* Everyone agreed the Trance someone else brought was great. Maybe the Five is rubbish? That'd do it.
That said, where exactly is the Trance faster and do you care about that bit? For example, I ride up hills to ride back down them, so uphill performance isn't important to me.
*It was so bad the attendant bike geek was convinced it had somehow been "put together wrong".
Posted : 04/03/2013 2:22 pm
I would guess the significant factor would the suspension set up.
Suspension design is not the issue it is the amount it bobs and sucks up the effort put in. An unsophisticated ssp with a big and plush stroke is going to eat up that effort, as would a flexy frame / wheels components.
If you locked all the travel out on both bikes you might even them up on the climbs but I assume you don’t just climb and then walk down! So its not really the bike being slower its just set up for different things.
Posted : 04/03/2013 2:36 pm
I've been thinking about this a bit more. The numbers don't lie, but I still don't believe them 🙂 I just don't believe that there is anything fundamental in the Five that would make it 10% slower than the Trance on average. Maybe a few percent, but not 10. Ten percent is a huge difference. I'm guessing that there is either some selection bias in the data I chose, or something different in the setup of the two bikes.
Of course, there are none so blind as those who will not see 🙂
Posted : 04/03/2013 9:22 pm
Rover. Could the 5 not be sucking 10% out of every pedal stroke compared to the Giant without you noticing?
Posted : 04/03/2013 9:41 pm
 igm
There's a long draggy fire road climd at Dalby (actually there are several, but one is a very steady climb), I was pooling up at 4 mph on the Garmin one time and half way up stopped just long enough to raise the saddle by an inch.
Instantly I was doing 5 mph, it felt the same and my heart rate in change. And the Garmin also gives the gradient and hat didn't change.
If I really was putting in no more effort, then getting the saddle height right was worth 20%.
Posted : 04/03/2013 9:58 pm
Efficiency of the bike suspension design and angles and perhaps more importantly the optimum ergonomic size and set up of the bike for the rider.
Obvious innit?
Posted : 04/03/2013 10:00 pm
Every bike I have owned went faster when I sold it........fact
Posted : 04/03/2013 10:06 pm
I'm not sure how many days you've conducted your evil experiments over, but could it be something as simple as differences in temperature which could affect both your performance and the ground conditions~ humidity may also have similar effects.
That said, you mention that the majority of segments were climbs, where the added fork travel and differing suspension characteristics would have a marked effect.
Posted : 04/03/2013 10:12 pm
Tyres…
A 28lb bike with small block 8s is going to be much quicker than a 24lb bike with super tacky minions… Like wise, a reasonably burly All Mountain bike with DH tyres is going to be quicker than a DH bike with XC tyres (on a DH course).
Extreme and silly examples but I find tyres the single most transformational thing on a bike. I wouldn't read anything into times without running like for like tyres.
People take the piss out of MBR for using control tyres in their BOTY tests but I always thought it gave the tests a bit of credibility tbh!
Posted : 04/03/2013 10:13 pm
But these rides were all done using the same wheels, tyres etc. I just swapped one set of wheels between the two bikes for dozens of rides over the course of a year, then looked at the best time for each bike over each segment.
Posted : 04/03/2013 10:44 pm
Well, the giant system as told by the mahs is supposed to be a more efficient system, but 10%? I'd be surprised.
I'd go with fit and how you ride the bike, it appears you have a maestro shaped pedeling style!
Is the mega mostly an uphill race? No? Then re-read the OP...
Posted : 04/03/2013 10:50 pm
I like you! :mrgreen: :mrgreen:
Fair play for doing a t-test mate, the magazines should be doing this in their tests! :mrgreen:
Posted : 04/03/2013 11:01 pm
Have we rules out contaminated beef?
Posted : 04/03/2013 11:04 pm
Commencal - SP
trek - SP
Cannondale - SP
I LOL'd my balls off.
Posted : 04/03/2013 11:05 pm
D0NK - Member
Commencal - SP
trek - SP
Cannondale - SP
don't most of those have a single pivot between the frame and the back wheel but a multitude thereof elsewhere? Might not be 4bar, vpp or DW but still (the possibility of being) a fair bit more sophisticated than the orange single single pivot?
Pretty much what I was thinking but when Thisisnotaspoon said 'Ohhhhhh dear' I couldn't really be bothered to reply as I had just brought up pics of each rider at the 2012 mega and found no simple single pivot bikes under each of the riders (bar a few of them)
They were pretty much all riding multi pivot bikes apart from a few that I couldn't find pics of during the race.
Out of interest, what psi were you running on the trance?
Posted : 04/03/2013 11:09 pm
They don't really work any differently to an Orange though, bar slightly altered leverage ratio's. At the end of the day you can tune for differing leverage ratios with an air shock by altering the air can volume/boost valve volume and the bottom out resistance.
Multipivots put less stress on the shock (I think) and allow designers to tune the leverage ratio a bit more but other than that there's no performance difference - the wheel arc is still exactly the same - they will still chatter over square edged bumps a bit more than a Specialized Four Bar setup with some rearward travel designed in. Theoretically anyway.
Posted : 04/03/2013 11:11 pm
Thanks bwaarp. Next week ANOVA 🙂
Posted : 04/03/2013 11:20 pm
So, what have you boiled things down to,Roverpig?
Posted : 04/03/2013 11:27 pm
Do the same test, but swap the wheels, bars and saddle each time. That way, you're left with suspension kinematics and the frame geometry as the only other variables.
The fit of a bike makes a significant difference that can be largely subconscious, for example, you won't notice yourself riding knock-kneed to allow your ankles to clear a suspension linkage, or whether you're holding back on the sprints because there isn't enough length in the frame to allow good breathing.
As for suspension, each system has a compromise. I've never owned a single pivot, but I have a Quad Link bike with some odd pedalling feedback. My other bikes have been Horst Linkage setups, but they feel very different and appear to have different axle paths.
Posted : 04/03/2013 11:40 pm
Actually, what I've "boiled things down to" is that it's damn nigh impossible to construct a test of two bikes that is remotely scientific, which isn't much return for months of work I'll admit 😳
I'd also conclude (and this is no big surprise) that a bike is the sum of its parts. I haven't done a test between a Trance and a Five at all. At best I've compared a stock Trance with a particular iteration of the Five, running a particular fork. Change the fork (or the size, or any number of other factors) and I dare say the results would be different.
Posted : 04/03/2013 11:42 pm
It's not the bike variables but the rider variables
It's all about sleep, you will be faster if you had a decent nights sleep before the respective test ride
And on that note I would like to thank the OP as I will at work 5 minutes earlier tomorozzzzzzzzz zzzzzzzz
Posted : 04/03/2013 11:52 pm
I think you're spot on rp, ride testing bikes isn't scientific. If it was more bike designers would be more lab based and it wouldn't matter if you rode much.
I find speed is affected mostly by my form or tiredness on a day, more than the bike unless there's a massive difference in type. Bike pros and cons often balance out over longer rides.What makes a bike work well for me is good ergonomics and a ride that suits both my riding style or needs and terrain. All pretty subjective stuff.
Posted : 05/03/2013 7:20 am
Is it likely to be the rear shock? If one locks out and reduces pedal losses better than the other you will be loosing a lot of uphill pedal energy into the shock? All other things being equal, I would look at this? Try riding uphill with the shock wide open (extreme example) and then locked out with pro-pedal or equivalent. Noticeably different in terms of energy efficiency. Just a thought.
Posted : 05/03/2013 7:38 am
Maybe you like your Giant more so ride it faster (subconcious thing).
After that, the size would get my vote.
Having said that the best DH race times I've ever had were on a Giant Glory.
(rather than numbers looking at other local riders that used to be ranked similar and how we compared on the day, I did significantly better against them on Maestro)
Posted : 05/03/2013 7:51 am
Roverpig: I saw no specific mention in your OP of tyres so wanted to check…
Posted : 05/03/2013 10:00 am
Thanks folks (and no problem Gary).
I have now found a climb where the Five beats the Trance. It's not a fair fight as the rides were six months apart, but it does reinforce the importance of the rider. The Trance is a bit faster (probably not 10%, but a bit), but the current me on a Five can still beat the me from six months ago on the Trance.
chilled76: No, I definitely like the Five more. If the stats had shown an advantage for the Five I'd probably have dismissed it as observer bias. But when the Trance comes out top I have to consider whether the difference might actually be real.
wavejumper: It could be the rear shock. I tend to use propedal to climb on both and, in theory, the RP23 on the Five should be better than the RP2 on the Trance. But the RP2 is new and I've had it serviced recently. The RP23 is old, bought from ebay and I have no idea if or when it was last serviced. It seems to be working OK, but I guess it could be stealing a few watts without me noticing.
At the end of the day though, none of this pseudo-scientific testing really matters. I can't think of a test that would really be scientifically valid (at least not one that I'd have the patience to do), so I'm left with subjective assessments of the two bikes, which are precisely that; subjective. It's all good fun though 🙂
Posted : 05/03/2013 10:50 am
I agree about the Giant Maestro that combined with the geometry of my Giant Anthem X made really fast on the road and on local XC bridleways.
I tend to keep an eye on top speed on some local road descents and I can't beat the Anthem's top speed on my hardtail no matter how hard I try. Average speeds over local XC loops were about 2-3km/h faster on the Anthem than the hardtail or my current FS.
I had a Fox RPL shock on the Anthem and actually found that locking the shock out made the bike slower than using the propedal setting.
Posted : 05/03/2013 1:35 pm
I asked a similar thing a year ago...
http://singletrackmag.com/forum/topic/what-makes-such-a-difference-mbr-content
Posted : 05/03/2013 1:39 pm
Well no, but it's about as good a measurement of having a play in the woods as I can see. As per the OPs:
It's generally won by fairly swift trail bikes, not DH rigs, Trance/Five would fit in perfectly well. What do you suggest I compare with, pro level XC? 2011 had 2x Fives in the top 10.
Woah, slow down, you're blinding me with science.
Posted : 05/03/2013 3:09 pm
To put it another way, a good chunk of the bikes in the top 10 are 4 bars. Yes, they're multi pivot, but they act absolutely nothing like Maestro/VPP. Their claim to fame is remaining active regardless of what's going on, not anti bob.
Much like single pivots, they rely on having loads of platform damping on the shock, much like the Specialized Brain shocks.
4 bar full sus mountain bikes have been around now for a good 20 years? Back from the days when half the backs coming out had unified rear triangles.
Posted : 05/03/2013 3:30 pm
It's down to new bike syndrome.
If you get a new bike that you like you ride it faster.
Weight, terrain etc don't matter and you're not a machine so you can't ride them both with the same effort.
The key is to accept that one bike is faster, cos then it always will be, and when you want to destroy your mates you just tell them that you're riding it. You will believe you are faster therefore you will be and equallythey will know you're faster so you'll appear even faster.
The above is all proven - I only have to mention I'm riding my Van Nic Tuareg and riding mates sigh and let me through so as to not hold me up.
Don't for goodness sakes question it, otherwise you'll ride the same on both.
Posted : 05/03/2013 4:32 pm
Just skimmed the previous posts so apologies if it's already been mentioned but my two-penneth : the more time you spend on a bike the quicker you'll be. It's all about being at one with your beastie...
Posted : 05/03/2013 4:51 pm
