What makes a helmet...
[Closed] What makes a helmet a certain size?
5 Users
I currently have a s/m helmet and looking at a few others they are one size. It got me thinking about what makes a helmet a certain size? Is it the shell or the band/strap inside the shell? Does a s/m helmet have the same shell as a m/l or is the shell bigger on the bigger size?
Posted : 23/10/2018 9:02 pm
I think it’s the headband/suspension setup, yes...
Posted : 23/10/2018 9:40 pm
Circumference of the head that will fit in the cradle though always good to remember S/M/L are letters and not measurements, so all good ones will publish the measurement that they designate to the letters.
Posted : 23/10/2018 9:42 pm
It depends on the manufacturer.
Some will produce a single shell size and alter sizes with padding/cradles. Others will use differing shell sizes to get closer to a 'fit', though still use differing pad sets.
It can look a bit mad having an xl shell on someone with a pinhead.. 😁
Posted : 23/10/2018 9:44 pm
Some will produce a single shell size and alter sizes with padding/cradles. Others will use differing shell sizes to get closer to a ‘fit’, though still use differing pad sets.
Interesting as being at the L/XL end of thing and a mate being XXL some stuff just sits on top of my head!! Not found many that will get big enough, some FF wont even go over the chin bar
Posted : 23/10/2018 9:47 pm
A ecent manufacturer will have at least 3 shell sizes and some have 5.  any helmet that you have to tighten a cradle to get it to "fit" does not actually fit and is pretty ineffective - TRL research
Its the shell that is sized.  It should be a measurement like 56cm which is the circumference of your head.  I have a medium helmet ( 56cm IIRC) which has the cradle fully out and it fits perfectly
Posted : 23/10/2018 10:03 pm
