What lock for groun...
[Closed] What lock for ground anchor?
3 Users
I've acquired a garage which has a couple of existing ground anchor points which are quite small and don't extend far above the floor
My Kryptonite D locks are too thick to go through the ground anchors so I need a thinner, more flexible lock if I'm going to make use of them
Any recommendations?
Posted : 26/08/2018 4:37 pm
If they're too thin to take a d-lock or motorbike chain, how much use are they anyhow?
Posted : 26/08/2018 4:39 pm
Maybe Martin
Posted : 26/08/2018 4:44 pm
 poah
you want 16mm at a minimum preferably 18-19mm.  if you can't fit that then they are not worth it.
Posted : 26/08/2018 4:53 pm
Hmm OK thanks this is more like a hole 15x10mm
Posted : 26/08/2018 5:07 pm
