What lacquer should...
[Closed] What lacquer should be applied to a gloss finish?
3 Users
I began spraying my bike with a high quality graffiti spray paint which is a gloss paint. The finish seems very soft and want to harden the finish. Should I use a lacquer? Any help is appreciated.
Posted : 11/02/2015 4:56 pm
I grabbed a big tin of PU Laquer in Halfords last week. Very hard, Very glossy. Do you warm your tins up in a bucket of warm water before you spray? You should if you don't.
Posted : 11/02/2015 5:00 pm
Regards the lacquer it will need to be compatible with the base solvent in the Graffiti paint otherwise the 2 may react and ruin the paint job any way.
Might be worth contacting the Graffiti paint manufacturer to see what they recommend, most have a help or contacts page.
Another option would be to cover the frame in helitape to protect it instead of lacquer.
Are you using Montana out of interest? I did a frame with that years ago and it never went hard. It chipped very easily and looked minging until I stripped it. Removal was also all too easy.
Posted : 11/02/2015 5:02 pm
Yes it is Montana. Thanks I'll try contact the page for any recommendations on the lacquer. Cheers
Posted : 11/02/2015 6:08 pm
