Still looking for the cheap\66.5 degree head angle hardtail frame for 120-140mm forks with no bolt thru axle etc
4560b would have been perfect for my needs 🙁
Ragley?
I doubt you'll find anything without bolt through axles now.
Even non boost is hard to find.
Get yourself a Genesis Latitude LT, fit superstar slackerizer? Longer fork at 140mm and that should be 66.5.
Vitus nucleus is slack and QR rear I think
Cotic.
Sick?
Cy saw the light with TA’s a couple of years ago. Pretty sure there are no QR Cotic’s left, although a sh Mk4 Soul (275) may do what you want.
DMR Trailstar. Comes with a 142 thru-axle, but as it has the V2 swopouts you can fit normal dropouts or horizontal dropouts too.
66 degree HT, nice and long, really low standover so you can size up easily, and rides lovely 😎 I did the 75km HOTS route on mine last weekend.
Currently £320 (down from £500) direct from DMR.
Those Sick! frames direct from Marino are cheap!
