What have I done to...
[Closed] What have I done to my Sektor forks?
1 Users
Sektor RL 2014 were feeling a bit sticky/losing their small bump ability so I removed the lowers for a check of seals and re-lube. Reassembled. nothing seemed wrong.
Now the initial 5-10mm are quite stiff and I can almost put my weight on them without moving, then they dive through travel and are very good on small bump, as though its dual air and you've got a lot more negative air pressure in the fork.
Not sure if its changed but they're a 140mm fork and they currently have 150-155mm of stanchion showing.
Posted : 01/12/2014 9:10 am
