Protecting the bolts and steel likely to rust bits on my commuter
Noticed that pedal axle, chainring bolts etc are getting effected by the winter roads and seem to remember a fat bike thread - coastkid? About using grease to protect bolts...
Oh, and where to buy too please? Thanks
I use Lithium 'white' grease
Stops rust and alu oxidising
[url= http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_214754_langId_-1_categoryId_165705 ]here's a link[/url] a bike specific version will cost twice as much for 4 times less.
I use a thin smear of copper grease on threads and seatposts. Though there are those who say it increase the chances of corrosion since it can conduct, I've never had this problem.
I'm about halfway down a tub after more than a decade of maintenance.
Copperslip / copper grease does NOT conduct electricity and certainly does not promote corrosion and is a perfectly appropriate product to use for lubrication, anti-seize and corrosion protection. Its just overkill as it is intended for uses in high temperature applications where normal greases will dry out or burn off (I.e many hundreds of degrees C). For bikes any old grease will do, but tat white stuff you get from bike shops will do for any bike application. For applications the OP wants, you want a good gloomy heavy grease that will not wash off.
I use copper grease on post/threads etc too - lithium is likely to wash off quite quickly I think. It's something really thick that will not wash off in winter grime
Incidentally I think the floods have killed my Shimano SS freewheel 🙁
Still looking for a heavy/gloopy grease recommendation - anyone please??
http://m.evanscycles.com/products/shimano/anti-seize-assembly-paste-455g-ec009017
Can't go wrong with this top stuff
When the other half was commuting I filled all the bolt heads with Vaseline or similar. Didn't budge even when I blasted it with a hose.
Can't see why a smear on the pedal axle wouldn't stop the rusting you mention...
