Im about to order a [url= http://www.ebay.co.uk/itm/GARMIN-USB-ANT-Stick-for-all-ANT-Compatible-Devices-NEW-01-001058-00-chip-/371229985288?pt=UK_CE_GPS_Accessories_Software_ET&hash=item566f080a08 ]Garmin ant+ chip[/url]
And also need a speed/cadence sensor.
Can I order anyone? Could I get this [url= http://www.giant-bicycles.com/en-gb/gear/product/giant.neos.ant.cycling.computer/574/50108/ ]Cycle computer[/url]
Or just this [url= http://www.giant-bicycles.com/en-gb/gear/product/giant.neos.ant.2.in.1.sensor/574/50104/ ]speed sensor[/url]
The Suunto Movestick Mini is usually cheaper than the garmin but otherwise that speed sensor should be ideal.
The sensor looks suspiciously like the decathlon one which is only £17
http://www.decathlon.co.uk/ant-speed-rate-sensor-cycle-computer-accessory-id_8181211.html
TR have a list of supported kit, some ANT+ sticks won't work with iOS devices for example. Start at http://www.trainerroad.com/getting-started or ask on their help centre.
A bucket also.
That ANT+ USB looks good and that speed/cadence sensor should be fine as well. You actually don't need the cycling computer in order to use TrainerRoad, but it would of course make a nice addition to your outdoor rides. Check out this article for more info on minimum hardware as well as some recommended devices:
[url= http://support.trainerroad.com/hc/en-us/articles/201542504-Minimum-Hardware ]http://support.trainerroad.com/hc/en-us/articles/201542504-Minimum-Hardware[/url]
-Trevor from TrainerRoad
A mat for the floor too in case you miss the bucket.
