What does Fit File ...
[Closed] What does Fit File Is Empty mean?
3 Users
Just recently bought a Lezyne Micro GPS and whilst it seems to have recorded mom/max/ average power and cadence for the ride overall, it appears not to have logged any other data.
Its done it for two rides on the turbo now.
The Lezyne app says "Fit file is empty" and Training Peaks just shows the above mentioned values for the whole ride, but doesn't seem to have logged the data over time?
Anyone had this problem?
Posted : 23/05/2018 9:47 pm
If you’re on a turbo what else do you expect it to log as you’re not going anywhere ?
Posted : 23/05/2018 10:01 pm
Probably depends how the logger works. If it records on a timebase then you’ll see what you wanted. Sounds like it has decided there is nothing to record as you aren’t moving because the GPS hasn’t moved. Is there an auto-pause you can turn off?
Posted : 23/05/2018 11:02 pm
