What do I need?
[Closed] What do I need?
6 Users
I have shimano brakes and the shifters bolt on to the same clamp. If I swap for SRAM brakes, is there a separate clamp I can use to keep the shifters?
Posted : 21/02/2015 7:14 pm
Any particular reason for swapping to SRAM?
Posted : 21/02/2015 8:23 pm
If you go for Sram brakes you'll need one of these:
Posted : 21/02/2015 9:30 pm
I have some Sram Guids and they are the best brakes I've had so far.
Posted : 21/02/2015 10:26 pm
Not since the Trails came out in 2013. Guides are even better, stonking reviews, but people will still choose to be a moron about it.
You'll need to have a look for the covers, I don't think you can buy them separately - but KCNC do some for the older style: http://clee-cycles.co.uk/esite/P20102/product
Posted : 21/02/2015 10:30 pm
Indeed, was always an Avid fan once used to bleeding (which really is easy). I've ridden XTs and now have a set of Deores but Guides feel so much better and more powerful so swapping the deores out. If I can get shifter brackets.
Posted : 22/02/2015 3:21 pm
Problems solvers (QBP) from Ison distribution do all sorts of odd mounts and adapters
But not looked at the range for a while
Posted : 22/02/2015 3:32 pm
