What CX/Gravel/Narr...
[Closed] What CX/Gravel/Narrow 700c/29 rims.
5 Users
I currently run some DT X470 rims on my Camino but it appears these are now discontinued ☹️
DT R500db rims seem to get decent reviews as do the H Plus Archetype rims both benefitting from being able to run higher pressures than the 470’s.
I’m only ever likely going to run 40mm (43 at a push) so low to mid 20 width?
Any recommendations?
Posted : 08/07/2020 7:38 pm
Have been very impressed with my Pacenti rims so far, off set rear spoke drilling which should build for a stronger wheel.
"Only" 20mm internal but they hold my 40mm Vittorias beautifully, a very floating ride at 40psi with no squirm or even a hint of bottoming out or pinching.
They also seem to go up tubeless very well, but that might be the tyre rather than the rim.
Not cheap though.
Posted : 08/07/2020 7:42 pm
Interesting.
I have a pair of DL31 rims that I’ve had for years but thought they were heavy for the width.
Are the newer rims comparable with the competition?
Posted : 08/07/2020 7:54 pm
Kinlin xr31t? Narrow, stiff, light and tough.
Posted : 08/07/2020 8:19 pm
If your never going to go above 55psi, Stan’s crest will build into a light wheelset.
Posted : 08/07/2020 10:05 pm
H Plus son Hydra are basically slightly wider Archetypes.
Posted : 08/07/2020 10:37 pm
