What CO2 inflator?
[Closed] What CO2 inflator?
7 Users
Want a CO2 inflator and 10 cartridges as cheap as possible. Can get the lifeline head for £7.19 from wiggle, is there better/cheaper?
Posted : 15/07/2013 9:31 am
Innovations Microflate Nano is my stock (one for commuting and one for road). Small and works perfectly. Uses screwthreaded C02. The press to activate ones are terrible by comparison.
Posted : 15/07/2013 11:23 am
Genuine Innovations Ultraflate Plus for me:
http://www.genuineinnovations.com/bicycle/mountain/ultraflate-plus-clone-2.html
Works really well on Presta (haven't tried schrader but it's threaded) and if you don't need a whole cart you can lock the trigger off. Lets you store the cartridges inside upside down so you don't have to break the seal until you need it. Takes threaded or plain so you're flexible of the cartridges you can use. I buy the cheapo brewing ones online, about a 10th of the cost from a bike shop! Last used a quick squirt at the weekend to pop some tyres on that my track pump couldn't get going when setting them up tubeless.
Posted : 15/07/2013 11:39 am
where are your cheap cartridges from
Posted : 15/07/2013 11:42 am
http://www.tyreinflators.co.uk/index.php
Got the Lifeline inflater a couple of weeks ago. I ended up using it twice yesterday (convoluted story involving getting hit by a caravan! 🙁 ) & it worked a treat. With a few of the inflaters you have to hold it onto the valve while you try to screw the cartridge into it which quite often means you lose gas. With this one you can screw the cartridge in, then when you push it onto the valve it releases the CO2.
Posted : 15/07/2013 11:43 am
hells - just bought that one cheers 🙂
Posted : 15/07/2013 11:45 am
Yep, get mine from the place variflex mentions.
Posted : 15/07/2013 11:46 am
If its a MTB tyre then be aware that a single cartridge wont fill the tyre so you need 2. When being used the cartridge gets extrememly cold and i found it difficult to remove my first cartride until it had thawed out. Just one of those little things that i never considered when buying...
Posted : 15/07/2013 11:47 am
would a 33g fill a 2.4 tyre or would i need bigger?
Posted : 15/07/2013 11:49 am
33g should be ok. I normally get through 2 x16g for a 2.1-2.25 tyre
Posted : 15/07/2013 11:51 am
@variflex Do you have any issues changing the cartridges whilst the fiorst one is frozen cold?
Posted : 15/07/2013 12:07 pm
For the road is it wise to carry a mini pump as well as CO2, and if so can anyone recommend a decent mini pump that would fit in a tool bottle?
Posted : 30/07/2013 7:07 am
