What chain tugs for...
[Closed] What chain tugs for a Cotic Simple
8 Users
 Jase
Come to the conclusion the hex bolts on the Simple are rubbish.
Should any chaintugs fit the Simple?
Any recommendations?
Thanks.
Posted : 08/02/2009 1:19 pm
Yes I agree the bolts are er not very good but to quote Cy "the are adjustable stops not chain tensioners"
The Surly chain tug fits and works ok, but look fugly I do not bother with chain tugs I like the "simple" look
Posted : 08/02/2009 1:56 pm
I'll send a pic of the fugly Surly Tugnuts later. I think they look fine, but they are SO HEAVY!
Fit absolutely fine by the way. Remember you only need one for the drive side...
Posted : 08/02/2009 2:17 pm
[img] http://www.surlybikes.com/parts/tuggnut_pop.html [/img]
Posted : 08/02/2009 3:29 pm
I've never had a problem with the Hex adjusters in two years.
I use Salsa QR's, it may be that yours arn't up to the job.
Posted : 08/02/2009 3:32 pm
 Jase
I've not even ridden the bike yet but attempting to turn the nuts is a nightmare and is starting to round off already.
Anyone sued the DMR tugs?
Posted : 08/02/2009 3:42 pm
I've used both the DMR and the Surly ones, The DMR ones are fine, you will have to carry a 10mm spanner to adjust IIRC. The Surly one is better IMO as you can use your fingers and it opens beer bottles too!* The Spot brand rocket one looks good too, but never had one of them.
* I like a drink, but I've only ever used mine once, and that was only just because 😀
Posted : 08/02/2009 5:07 pm
 Jase
Cool, used to carry a spanner to adjust the dropouts on my voodoo.
Thanks.
Posted : 08/02/2009 5:10 pm
You might need to file the flange a bit on [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=216 ]These DMR ones[/url] as I think the Simple has cowled dropouts similar to a Surly frame. If it helps the Surly one should fit better, but I have a Soul, not much call for chaintugs on those 😉
Posted : 08/02/2009 5:20 pm
I tell a lie, the hex's where pants. Get some M8 bolts instead (£3 from ebay), thats what I have and they are a heap better.
Posted : 08/02/2009 7:26 pm
Are you talking about the chain-tensioner bolts that are hard to turn?
If so you are releasing the hub first before trying to force it backwards?!
I usually pull the wheel back by hand and tighten the hub. I then simply screw the chain tension bolt lightly back into the hub to stop it from being pulled forward.
Posted : 08/02/2009 8:02 pm
 Jase
Yep, they aren't even screwed in far enough to protrood through the frame to make contact with the axle!
Posted : 08/02/2009 8:07 pm
shouldn't a frame that expensive be free of drop-out chain-tug issues?
and be ready to roll out of the box? (with a quick adjustment of the dropouts)
Posted : 08/02/2009 8:34 pm
Jase, it sounds like the threads have been clogged with paint. If you can run a thread tap through that would sort it out. A cheap one off Ebay would work fine for clearing paint. You could always Email Cy see if he will send you one to borrow, and a new unmangled bolt too.
Posted : 08/02/2009 9:36 pm
I replaced the bolts on mine with decent quality stainless steel SHCS which work fairly well. I also use a socket-head skewer too to get it tighter. Mind you, don't know if mine's differenet cos I'm running a Rohloff hub.
Posted : 08/02/2009 9:57 pm
I accidentally bought half a KG of the bolts, pm me your address and I'll wing you some.
Posted : 09/02/2009 8:29 am
 Jase
seanoc - cheers but can't find your email address.
Can you mail me on jaykeenor at sky dot com
Many thanks.
Posted : 09/02/2009 8:23 pm
M8 bolts they are just [b]alot too big[/b] I had to clean the threads on my simple dropouts with a M4 0.7 tap
Posted : 09/02/2009 8:29 pm
 Jase
Many thanks for the bolts seanoc, much better than what the frame came with.
Cheers.
Posted : 11/02/2009 8:18 pm
