I don't want to chew up my new Freehub. Does the 10speed XT cassette have a full aluminium carrier?
Cheers.
I've used XT on mine but it's 9 speed and the cassette literally falls straight off with the retaining ring removed and shows no signs of chewing the Freehub.
there are 2 seperate cog stacks on the 10 speed XT (M770). Which are the largest 3 cogs on 1 stack, the next 3 on another stack, and the remaining 4 loose.
you will always get some gouging on the soft alloy body of the Pro II, make sure to grease the body before fitting the cassette, and use a torque wrench to set the cassette lockring at 40nm.
Thanks fellas. I'll probably just use an SLX then... And a torque wrench
Or, get the steel freehub bodybody, it costs no more.
I will do Core, when this one finally turns to cheese
