What brake mounts d...
[Closed] What brake mounts do I need?
2 Users
Hi, could someone just confirm what brake mounts I need for a 2015 Nomad CC build, it will be for SRAM Guide R brakes with 180 rotors.
Rear I guess is IS to post?
The front I am not sure, it will be going on a set of 2015/2016 Fox 34 Kashima forks
Posted : 12/05/2017 8:04 pm
bump
Posted : 13/05/2017 10:23 am
Also just to update it will be Shimano XT brakes, the new M8000 version
Posted : 13/05/2017 11:18 am
If you're going Shimano the front will be a PM to PM +20 standard mount, on the rear a lot of frames nowadays seem to come with PM rear mountings on the frame so check the frame specs before you buy anything.
Posted : 13/05/2017 1:29 pm
