What bottom bracket...
[Closed] What bottom bracket (Giant Talon)?
5 Users
Mr TW has a 2010 Giant Talon 0 which we are using as a turbo bike. The bottom bracket needs replacing. I can't find the spec anywhere but I'm fairly certain it is Octalink. How do I work out what size? Where would I measure it?
Thanks for any help.
Posted : 01/03/2019 7:26 pm
Remove the old one. It should be labelled with the relevant sizes. You need to know the BB width (68 or 73 mm), E-type or regular derailler, plus spindle length. The spindle length is the tricky bit. I think 113 mm is most common, but they vary according to the specific cranks.
Posted : 02/03/2019 9:38 am
I've got an ES25 68x113mm, ES52 68x118mm and a ES51 73x121mm.
If you find out its either of those you're welcome to it for postage. All running fine.
[url= https://i.postimg.cc/W4Tkmwfd/20190302-094121.jp g" target="_blank">https://i.postimg.cc/W4Tkmwfd/20190302-094121.jp g"/> [/img][/url]
Posted : 02/03/2019 9:40 am
If your lbs is a giant dealer, take the frame number to them, they can punch it into the dealer site and it will tell you and them exactly which one you need.
Posted : 02/03/2019 1:02 pm
Thanks all. Took it out and looked. Cheers for the offer Ads but it is a 68x121.
Posted : 02/03/2019 3:34 pm
