What bearings fit/a...
[Closed] What bearings fit/are recommended for this Mavic wheel?
3 Users
Hi. Sorry this is quite a boring thread. Unless something unforeseen happens, anyway.
I have some Mavic Crossmax SX. They're getting on a bit now I expect, I bought them second hand a while back. They look like [url= ]these[/url].
There's a bit of play in the rear hub so I think I need new bearings. I [i]think[/i] they're 2009? If anyone could confirm that and also point me at some good reliable replacements that would be super lovely. Thanks. I found some on eBay that I think are right but I'm less than certain.
Posted : 10/09/2014 3:19 pm
2009 model SX
play in the hub isn't necessarily a problem, as they are adjustable - did you get a little spoke wrench with pegs on it? I'm guessing not second hand -
put wheels in frame, tighten QR and spin wheel - on the NDS there will be some little holes, put the tool or a pin spanner n the holes and tighten GENTLY till you see a bit of resistance (wheel slowing) - then back off 1/2 a turn and they are set correctly.
ignore slight play when unladen as a sign, the above is the correct way to tension the bearing.
if they DO need new bearings, then off the top of my head it would be something like a 6903 and a 6082RS (might be wrong on that, ages since I looked, check the numbers on the ones to come out)
if the freehub bearings are shot, then the correct action is a new freehub body (and you may need a new axle too, as they changed the freehub and axle, the newer axle had a blue spacer on the NDS, the old freehub no longer available, though you can drift out the freehub bearings and replace with likewise, you just need something like a small vice to set them back in the body, but not too tight (theres a metal spacer in the middle, and if that is too tight on the bearing it doesn't spin freely.
hope that helps
Posted : 10/09/2014 4:53 pm
Thanks guys. I'll see if adjusting the tension works first then, nice one.
Posted : 10/09/2014 6:20 pm
