I am looking for a set of bars and stem to go on my rigid 29er,anyone got any suggestions or using something they would recommend.
What you got on your other bikes?
Use them.
some of those lady bars on joneses or on ones. 😉
High rise
Medium rise
Low rise
Flat
Mary
Fleagle
h
carbon
alluminium
Easton
USE
FSA
Titec
And a million others will all steer it quite well.
And dont even get me started on Grips.
If you're on a 29er to try and be 'different' then make sure you get some funny set up or you'll be shunned by the proper niche-wh0res - maybe some roadie drop bars or pretty much anything other than a riser or flat bar.
Otherwise, just use what you have on your other mtbs but maybe with a lower rise for the bar or flatter angle for the stem to make up for the typically higher front end on a 29er.
agreed.
Im currently using mid rise monkey bars, which even with a 5degree flipped stem is a bit high with the big forks (OK with rigids) so I may hunt down some flat bars soon.
