Fitting some new SRAM brakes and, while I've had a load of sets I don't *think* I've ever bled a bleeding edge equipped set.
my box of oils and syringes has both of these in it. I've got a load of reverb syringes which have a simple brass screw adaptor on the end, then this Rock Shox branded syringe with a weird silver end to it and I cant remember what it came from. Anyone recognise it?
It doesn't look like a bleeding edge adaptor - the OEM ones appear to be red and to have four 'arms' in a cross (this only has two). the other one is what what I *think* I bought from EpicBleedSolutions as a bleeding edge. But the sealed packet was unlabelled...
Bleeding edge for Reverb 1x lever
For a Reverb 1x lever.
Edit - Damn, 7 seconds too late.
Those are for a Reverb and not brakes.
The epic one is for brake caliper
Ah - that explains why I've only got one. only have one 1x lever in the house.... so it uses a *different* bleeding edge tool to anything else. Good work - at least they must have supplied that with the lever.
The round one is for the brakes and the other one is the reverb one.
