So I was having a sort out and found these in the garage:
I'm 100% sure they're something to do with a shock or fork, and I'm guessing they're spacers for an air shock to tune the shock (Bottomless tokens etc). The question is can anyone tell without me if these come from a ~2011 RockShox Recon fork, or ~2011 RP23 shock?
spacers to reduce travel in forks.Used some to space some Lyriks down to 140mm to suit the bike they went on.
Ah yeah that's also an option.
Thrunge gaskets.
Looks like they're Imperial, though. Most modern ones are metric.
Looks like they're [s]Imperial[/s] Whitworth, though. Most modern ones are metric.
Come on Flashy. Do you not know your Whitworth from your BSF and AF. 🙄 😉
#hipster
#hipster
Not quite. Sadly I'm old enough to have had to use Whitworth spanners in my first place of employment. 😳
I knew I should have asked this on a work day!
They are Rock Shox travel spacers for the recon forks.
Two votes for travel reducers, thanks everyone.
