What are the good p...
[Closed] What are the good points about heavy bikes?
36 Users
Because I just realised how heavy my steel Cove Sanchez is in comparison to my old frame...
is it easier to keep a constant momentum, due to the weight?
Posted : 07/06/2012 7:35 pm
Another excuse....
Posted : 07/06/2012 7:38 pm
"Another excuse...."
Excuse for what?
I'm not making excuses for anything.
Posted : 07/06/2012 7:39 pm
Anything really........(insert failure here) because my bike is heavy.
Posted : 07/06/2012 7:41 pm
Can feel a bit more stable downhill imho but aside from that, can't really see any benefits. Heavy doesn't always mean stronger..
Posted : 07/06/2012 7:42 pm
I'm not blaming my bike for anything. In fact I can't wait to get my wheel built and then ride it, I imagine that it'll be super stiff and sturdy, if not slightly challenging to ride, but hey I could use the exercise of riding it. I'm just wondering what kinda benefits go with weightiness...
Posted : 07/06/2012 7:46 pm
Bike weights along with wheels weights, and along with the minutiae of stem, handlebar, seatpost etc., are massively over-rated in terms of performance.
Consider your all up, ready to ride, stepping out of the door weight with your other bike, then compare it to your new bike.
What's the real difference? 2kg? 3kg? from an all up weight of 95kg? 100kg? 120kg?
Think about it sensibly....
Posted : 07/06/2012 7:50 pm
If the combined weight of you & your bike is heavier than anyone else you ride with then you will go faster downhills. To some degree/at some/given point.
I know this cos I'm loads heavier than my mate (same bike weight or thereabouts) & I go faster than him without pedalling, generally.
Posted : 07/06/2012 7:54 pm
i dont reckon weight makes that much difference.
geometry on the other hand . . . .
Posted : 07/06/2012 7:55 pm
From [url= http://covebike.com/bikes/sanchez ]Cove's website[/url]:
For those who aren’t afraid of the nasty, we introduce Sanchez, our dirt jump/street weapon
So nothing wrong with a bit of weight for dirt jumping or street riding.
Posted : 07/06/2012 7:58 pm
Bike weight's just something to get used to. I've always owned heavy bikes and get on fine with climbs as well as descents. Makes life a lot easier when I borrow a lightweight bike too.
PS Tyre choice and pressure will make a whole lot more difference to downhill speed than bike weight ever will
Posted : 07/06/2012 8:01 pm
[i]i dont reckon weight makes that much difference.[/i]
Some law of fizzics would probly suggest otherwise.
Posted : 07/06/2012 8:04 pm
 grum
The good point about my heavy bike is that it has lovely plush-feeling coil shocks front and rear, and a dropper seatpost.
 mboy
Main benefit of a heavy bike over a light one that I can see... You will get fitter!
Otherwise, too many variables. Heavy does not equal strong all the time, nor faster DH, nor easier to keep momentum etc. Heavier just means heavier, which definitely means harder to pedal uphill.
Posted : 07/06/2012 8:11 pm
generally, heavier isn't better*. But saving weight gets very expensive, very quickly.
(*although i find that light wheels can feel a little nervous in techy bits compared to heavier wheels/tyres, yes i am rubbish, and could use a big dose of man-up)
Posted : 07/06/2012 8:21 pm
well obviously id rather ride a 7kg superbike than 18kg supermarket special, but i weigh 135kg, losing a kg off a bike doesnt even equate to 1%.
geometry is probably going to have a bigger effect on ride feel than bike weight.
mebbe not as much as going on a diet tho.
Posted : 07/06/2012 8:32 pm
I'm 9 stone, my big bike is 33lb/15kilo so in effect a quarter of my bodyweight, which is probably a higher ratio than most people on here.
I can climb easily enough on it, not as fast as on my 26lb bike but not that much slower.
Personally i think geometry etc are far more important than weight alone.
Posted : 07/06/2012 8:42 pm
Heavy can be more stable- I knocked 10lbs off my downhill bike over time and it does get bounced around more easily than it used to. But that's just a flipside of it being easier for me to move around.
Posted : 07/06/2012 8:45 pm
Me & my pal have very similar bikes, mines about 2 lbs lighter & I'm about 3.5 st heavier than him. On a similar climb he's quicker than me & on a similar descent I'm quicker than him.
It's all relevant innit.
Posted : 07/06/2012 8:50 pm
My bike weighs about 35lbs. I'm closer to 210. My bike is stable at speed through the rough stuff and I'm never last up the hill so it must be making me stronger.
So ! A good point about a heavy bike is....
It makes you strong 🙂
Posted : 07/06/2012 8:59 pm
They make better anchors? 😛
Posted : 07/06/2012 9:29 pm
Make you strong, like bear.
Posted : 07/06/2012 9:57 pm
They are more robust, generally, because the parts are strong, as opposed to some super lightweight weight-weenie stuff which fails if looked at in the wrong way.
Other than that I don't see any benefits - even downhill I much prefer a lighter bike as it's much easier to chuck around and flick, rather than having to wrestle it around.
I suppose it will make you stronger as it takes a bit more effort to ride.
Posted : 07/06/2012 11:16 pm
Stick 2.35 Stickee Nevegals on a 24lb rigid ht & I bet it will feel slower than a set of Smallblock8's on a 30lb fs bike. Inbreds, on paper, are hefty old iron clunkers, but they don't ride like it.
Posted : 07/06/2012 11:41 pm
Have you tried swapping bikes? My physics is a bit rusty. but shouldn't all things fall at the same rate on Earth.. air resistance etc aside and being fat should increase resistance. I'm guessing your bike has less rolling resistance or it's your technique (subtle pumping etc).
Posted : 07/06/2012 11:57 pm
For bikes, choose two of the following only.
Cheap,
Light,
Strong.
If your bike is heavy, you can conclude then that it's cheap and strong. They must be the advantages of a heavy bike if you like it or not.
Posted : 08/06/2012 4:52 am
Yes. If you dropped two bikes off a cliff and one was 20lbs and the other was 35lbs, it would be resistance that dictates which one hits the ground first not weight. It's possible that the lighter bike will hit the deck first if it falls in a manner that offers less air resistance.
Posted : 08/06/2012 6:43 am
So the fat boys should accelerate faster, no?
Posted : 08/06/2012 8:45 am
 wl
I guided for a season overseas, and it was always the people with super-lightweight bikes who went home gutted thanks to big dents in their wafer-thin down tubes after the inevitable crashes. Occasionally their bikes snapped too, but at least they were light enough to carry back to the chalet.
Posted : 08/06/2012 8:54 am
nice diagram.
but no.
Posted : 08/06/2012 8:56 am
Inertia is something that you might want to read about
Posted : 08/06/2012 8:58 am
yeah being heavy doesn't make you descend faster (think of the feather vs lead experiment on Moon). acceleration due to gravity is a constant 9.81 ms^2 approx. but being heavy means more kinetic energy (0.5mv^2) which will make braking less effective. heavy wheels might make the bike more stable due to gyroscopic forces (can't think of formula - that's above GCSE physics!) though, no other advantages i can think of.. assuming light bike is strong enough.
one thing i thought maybe weight could push the tyres into corners so perhaps more grip is an advantage, but then it's harder to get round the corner (cornering is also a change in velocity (even if speed is constant), more mass to accelerate) so that probably cancels out any advantage there.
TL:DR more weight is probably a slight disadvantage going down, and a big disadvantage going up, which you and bike makers already knew :p
Posted : 08/06/2012 11:57 am
Being heavier doesn't necessarily mean any more grip - friction is proportional to force applied (i.e. mass), at a macro Newtonian level, but so is the force you need to chance direction, so it all cancels out.
Posted : 08/06/2012 12:04 pm
If you want to beat someone to death and only have your bike at your disposal, heavier is better.
Posted : 08/06/2012 12:14 pm
In the case of a frame like a Sanchez, a lot of the extra weight will come from the thicker tubing used. Meaning you'll be able to case jumps and smack into stuff with less fear of something like this happening.
http://www.flickr.com/photos/74729001@N00/4725375799
Posted : 08/06/2012 12:16 pm
 br
Good point - cheaper than a lighter one.
Posted : 08/06/2012 12:18 pm
OP you've combined 2 separate things: your frame is heavier because it is built for thrashing n crashing. As long as a bike is strong enough for the rider and purpose it does not benefit from surplus material.
Unless competing I don't think it's worth getting hung up on weight. My current bike is heavier than the last but performs better and as such I am riding the same trails faster. I climb a little slower (or sweatier) but I see uphill as a necessary evil.
As mentioned body type relative to the bike has a big affect. A biffer on a feather or a XC mincesnake on a DH bike aren't quite optimal due to the demands/function of the task in hand.
Do you ride DJ/street/jumps etc? If not you may have an inappropriate frame. If you do ride that sort of thing, then you're in the wrong club for weenie weight watching.
Posted : 08/06/2012 12:25 pm
Without a heavy bike I wouldn't be able to go for a bike ride at all. (I don't own any weeny-weighty bikes, y'see.)
Posted : 08/06/2012 12:26 pm
Your girlfriend won't nick it? I only 'borrow' the light bikes from my long suffering bf.... reckon it's justified on weight to bike ratio 😀
Posted : 08/06/2012 12:46 pm
pmsl @ xc mincesnake.
that has properly cheered me up on an otherwise boring day.
Posted : 08/06/2012 12:54 pm
My Carrera Banshee X with bombers on the front never seems to break.On the other hand the posers on here with there 3 grand+ bikes are always moaning about breaking frames/ parts.
Posted : 08/06/2012 4:42 pm
I think the obvious flaw in having a heavy bike is that it really hurts when it hits you on the back of the head after you have just "superman'd" over the bars............... 😉
Posted : 08/06/2012 7:20 pm
no, they ride more like this
weight's not that important as long as you are having fun though! If it's such a beast that it becomes a chore to ride is when it's a problem
Posted : 08/06/2012 7:39 pm
Okay stop me if I'm wrong, I know that being heavier doesn't make you fall/descend faster, because thats about air resistance, but is it easier to maintain your' kinetic energy with more weight?...I'm no good at physics.
...That is seriously good use, that and someone said when they borrow lighter bikes it's easier.
Posted : 08/06/2012 9:26 pm
kudos100 - Member
I think I could wield a lighter bike more effectively
Posted : 08/06/2012 9:35 pm
light stuff is more expensive!
heavy bikes burn more cals/get you fitter and give your friend one less excuse as to why you beat them up the last hill 🙂
current ride is a 32lb blue pig and its going to be putting on a little more weight soon. rides great.
Posted : 08/06/2012 9:45 pm
