What adapter / leng...
[Closed] What adapter / length bolts - 220mm rotor?
5 Users
I need a new rotor for my bike - ordered a 220mm Centerline rotor which is 20mm bigger than now.
I have a 2021 Lyrik Ultimate - it’s currently got a + 20mm adapter on it to run a 200mm disk (fork is 180mm post mount).
Which mounts for a front brake +40mm will work with a code caliper (I think I had a lifeline one before which the caliper clashed with) and what length bolts do I need please?
Ideally not one that costs £25 either if possible. I can see total bleed solutions do a Magura 180-220 mount but it’s not obvious if it has bolts. I think Magura calipers are chunky so probably would be ok with codes?
Posted : 20/03/2022 6:32 pm
Hope M adapter with normal 20mm ish bolts, get rid of the awful type adapter that requires 2 different length long bolts.
Posted : 21/03/2022 8:36 am
Why not just buy the Sram +40 PM to PM adaptor? You have a Sram fork and brake.
Posted : 21/03/2022 4:41 pm
Failed to find the Sram +40mm post to post adapter.....
Ah hang on - there’s an avid one on biketart. That hasn’t come up before.
Posted : 21/03/2022 4:48 pm
I tried with a +40 and long bolts on a mezzer but the caliper position was quite low so switched to an offset 4 bolt mount.
I also found it slightly harder to set up the caliper square but that was probably more to do with bolt clearance in the mount
Posted : 21/03/2022 5:18 pm
If not clear, this is the one that I mean:
https://www.worldwidecyclery.com/products/avid-sram-disc-40mm-post-mount-adaptor-fits-200mm-front-and-180mm-rear-rotors
I had it on both my bikes (Lyriks and Code or G2 calipers)
(Ignore the 'fits 200mm......' in the link.... Obviously it depends on the fork brake mount as to what adapter you need, so it's not a '200mm adapter')
Posted : 21/03/2022 7:55 pm
FWIW magura mounts come with bolts
Posted : 21/03/2022 8:26 pm
