Wet weather
[Closed] Wet weather
5 Users
Hi after coming off my bike the other night in the wet could someone please advise some good wet weather tyres for a mountain bike?
Posted : 07/10/2015 9:58 am
Firstly what tyre do you currently have and what pressure was it pumped up to?
Posted : 07/10/2015 10:49 am
on or off road?
mud or rock?
more info required mate.
Posted : 07/10/2015 10:52 am
If you were on road with high pressure on the MTB then you will come off more than stay on. Especially in built up areas where oil & fuel and general sh!te is on the roads
Posted : 07/10/2015 10:57 am
Thanks for the reply. Sorry for the lack of info I currently I've got schwalbe marathon plus tour and they were pumped up to 65psi. 90% of the time I'm on the roads using it for work
Posted : 07/10/2015 10:58 am
What pressure do you recommend and do you also recommend better more grippy tyres?
Posted : 07/10/2015 11:04 am
More tread does not necessarily make you safer on the road- if you think about a road tyre, like yours, on the road there's a lot of rubber in contact with the road. If you think about a big knobbly mountain bike tyre then the tips of the knobbles will be in contact with the tarmac, which is much less rubber and so much less grip.
Off road a mud tyre, like a Specialized Storm, would work, but on road they will be more of a liability.The tyres you have already are probably the best for the job you are doing and the pressure sounds OK too. I think you just need to be a bit more careful if you're not that confident about bike handling in the wet.
Posted : 07/10/2015 11:19 am
Thanks for your reply. I only got these tyres in the summer as I was fed up with punctures and they have been great for that but since the weather has turned wet I have felt them slipping. I have been doing the same ride to work for over 10 years through all seasons so I don't think it's a confidence issue (although the drives on that particular road are getting more reckless every day!). I was just wondering if there were better tyres for the job.
Posted : 07/10/2015 11:37 am
