Weightists - a chal...
[Closed] Weightists - a challenge for you...
18 Users
I keep coming up with different answers using the web only, so let's see if we can get 2 people to match. Right, ready? Well then, what's the weight of my bike:
enigma ego Ti 17.5
2012 XT 2 x 10 groupset 28/40 and 34/11 with ice tech 160mm rotors
M520 pedals
2012 Sid RLT Dual air steerer 200mm QR
2012 American Classic XC 26" wheel set with AC qr's
F Nobby nic 2.25, Rear 2.1
enigma carbon seat posts
Enigma ti railed saddle
Thompson 90mm 6 degree stem
Raceface dues XC bar 2012
Xt cables and outers
Enigma headset
Salsa qr
I'll check back in the morning and see how many different answers there are 😀
Posted : 02/12/2013 10:20 pm
Why don't you just weigh it? 🙄
Posted : 02/12/2013 10:23 pm
19lb - or are you using proper scales ?
Posted : 02/12/2013 10:24 pm
 DrP
Four?
DrP
Posted : 02/12/2013 10:26 pm
The most important weight is the big lump sitting on it 🙂
Posted : 02/12/2013 10:30 pm
Crkey - I only have bathroom scales. Scaredypants - I got 19lbs too but it feels much heavier than that.....
Fast haggis - I've lost 13lbs sin July and still going...
Posted : 02/12/2013 10:31 pm
no way 19lbs, scales are way off. Frame is probably 1.3 -1.4 kg, heavy forks, rotors , stem, bar , groupset etc. I would say more like 23lbs
Posted : 02/12/2013 10:33 pm
I'll bid 24lbs. No way is that anywhere near 19.
Posted : 02/12/2013 10:36 pm
 beej
Grips?
Rim tape?
Which model of Nobby Nics?
I'll guess it's the weight of a medium badger, male.
Posted : 02/12/2013 10:39 pm
Ah. Renthal Kevlar grips, Stan's yellow tape and non tlr Nics, triple nano Evo.
Posted : 02/12/2013 10:41 pm
Not seeing 19lbs, more like 21 and a bit of change.
Posted : 02/12/2013 10:43 pm
(should stress, my 19lb was a joke)
/edinburgh
Posted : 02/12/2013 10:58 pm
If you're in Space the weight is zero.
Posted : 02/12/2013 11:06 pm
Low 20s, daft to try and get closer than that tbh but if I had to, I'd say 23lbs.
Posted : 02/12/2013 11:08 pm
Sort of. You'd have a tiny (yes, negligible) weight if you are within the gravitational pull of a planet/star/astroid/comet/lump of whatever/lost aliens 😉
Posted : 02/12/2013 11:18 pm
22.75lbs ... or sensibly light. I have something similar - just get out and ride it and don't worry about a few lbs 🙂
Posted : 02/12/2013 11:39 pm
~23lbs also, or on my scales, 'wgas there's nothing heavy on it and some stuff may need to be beefed up'
19lbs, no chance )
Posted : 02/12/2013 11:51 pm
The number is always 42.
The only problem is finding a suitable unit for the number.
Posted : 02/12/2013 11:58 pm
 DanW
This... or maybe this
I'll bid 24lbs.
Definitely this
Posted : 03/12/2013 12:46 am
32lb
tubes? Tubeless? how many cups of Stans?
Posted : 03/12/2013 12:53 am
Tut. It's not 32lb.Tubeless, 1.5 cups of Stan's in each tyre
Posted : 03/12/2013 6:55 am
23-24 seems about right
Posted : 03/12/2013 6:57 am
Njee if you just happened to be carrying your scales later this month... 😀
Posted : 03/12/2013 7:10 am
