Hi,
I've been using M520 and now M540 SPDs on my commuting / training road bike and find that they dont seem to last long.
They get slopey / creaky.
Do the pedal frames / platforms wear out, or is it likely to be the bearings need a grease and the cleats (which admitedly I dont change often)? Are there any wear indicators on them?
Are there any recommendations for a robust pair of SPDs that will live up to heavy use in all weathers (on the road)? Or do my M540's just need some love?
Probably worn cleats .Try winding the tension screw in a bit as well
That surprises me. I've had M520's on mountain bikes for 5 years plus with no issues. I've also had the same pair on my 29er fixie for over 2 years and they take a proper pounding on that due to increased pedal strikes. Still going strong.
Edric64's advice sounds good.
They are already set to the stiffest setting.
I'll try some new cleats, but given the cost difference, I might just get another set of M540s, I've just seen that they've got great reviews.
If they are creaky then it could be the bearings. They are pretty easy to service as well, regrease, tighten them up again and then I tend not to touch them for at least a couple of years.
I've had a ridiculous number of sets of 520s, 540s and predecessors on various bikes over a lot of years. It takes a lot of abuse to kill them on a mountain bike, on a road bike I would expect (and get) years of use without bothering to maintain them.
As above if they get sloppy a bit of attention to the bearings usually helps - the specific cone/locknut tool makes it really easy but its a bit pricey.
Bet its the bearings that are adding to the movement. tidy that up first. Cleats may be worn but you can use them for ever.
I had about 3 sets degrade to sludge inside well beyond a grease and get going. For the price they got binned, worn cleats are hell you only know they were bad when you put new ones in and everything feels right again (repeat periodically)
Worn cleats will make creaking noises.
[quote=ChunkyMTB ]Worn cleats will make creaking noises.
Thats a new one to me, it was normally the foot leaving that gave it away
sometimes you don't know it all...
New cleats ordered (£7 on ebay) and will regrease the bearings.
Thanks for replies.
