Wax type chain lube
[Closed] Wax type chain lube
17 Users
I'm a fan of wax based chain lube. I use Putoline hot wax through the wet season/weather and squirt lube in the summer.
However, I find squirt washing off a bit too quickly in puddles and wet mud during that in between season.
Anyone know of anything that fills the middle ground? I've got a riding holiday coming up soon and squirt might not last if it's wet, but the Putoline can't be reapplied on holiday and may not last a full week.
Posted : 19/10/2016 7:53 am
I have a bit of Squirt in an eye drops bottle
Posted : 19/10/2016 8:02 am
I've a small bottle of it, but it's not ideal to be applying mid ride.
Posted : 19/10/2016 8:07 am
putoline will last a week no problem IME
Posted : 19/10/2016 8:12 am
Squirt, all year round. I don't have issues with it noticeably washing off. I'm sure it does a bit but it's important to note that it's not the surface which counts, it's inside. The surface is fine looking like it's got nothing on. I test by running fingers over the rollers and if they seem loose, needs more of the stuff. If there's some resistance or stickiness then it's fine.
Key also is to leave it a while after applying to dry. It will wash off otherwise. Re-apply for each ride. Don't de-lube, let the stuff build up inside.
Posted : 19/10/2016 8:13 am
Fenwicks stealth is good, seems very wax like, it's quite thick. Lasts a lot longer than squirt, doesn't get that mucky, and is less faff than putoline.
Posted : 19/10/2016 8:19 am
Putoline might last a week, depends on the conditions. But you can top it up too, I just put finish line over the top of it if it wears thin.
Squirt's very situational- in some conditions it lasts well, in others it wears off ridiculously fast, in some it goes sticky.
Posted : 19/10/2016 8:26 am
Putoline for the week really depends on just how much crap it's exposed to. I've had it not last a weeks holiday before.
Posted : 19/10/2016 8:52 am
Squirt all year round for me. When very wet n muddy then I need to reapply after a wipe down. In Adam this year I need to bung some wet finish line on 2/3rds into an all dater with biblical weather. Otherwise it's too top
Posted : 19/10/2016 11:05 am
Squirt becomes rather more viscous (and tenacious) when it's been frozen and thawed
Posted : 19/10/2016 11:09 am
I'm going back to squirt. I think I prefer having a cleaner chain, albeit maybe one with less lube, than a chain that is well oiled but had collected so much crap it wears just as badly and is a pig to clean.
I've bitten the bullet and bought a 500ml bottle and will just apply fresh the night before any ride.
Normal oil will be kept for the commuter that doesn't see much love.
Posted : 19/10/2016 11:39 am
 pdV6
I just whack a bit of Squirt on after a ride, all dry & ready for the next one.
Posted : 19/10/2016 11:46 am
I normally wipe down and apply squirt the night before so it's had time to dry but in certain sloppy conditions, it does just turn into a soup.
I'm just wondering if there's something like squirt that's better in the wet but with a more travel friendly application method than putoline.
Posted : 19/10/2016 11:59 am
Well I do think fenwicks stealth ticks those boxes.
Posted : 19/10/2016 5:23 pm
Finish-Line White Lightning here, e-mail me your adress and i'll post you some to try if you want.
Posted : 19/10/2016 6:14 pm
Another squirt user here. As above, would rather a clean drivetrain that needs a regular application than a shitty drivetrain that's hard work to clean and wear quicker. Can't see me going back to anything else.
Posted : 19/10/2016 7:12 pm
Not sure this helps much, but when away with my bike I use a wax based dry car cleaner - spray all over (except disks), wipe off with micro fibre cloth (no bike washers for me). The wax builds a protective coating on the bike so mud falls off and reconditions the chain between putoline. Sure somebody will tell me I'm doing it all wrong but seems to work fine for me.
Edit - I use the turtle wax dry wash stuff
Posted : 19/10/2016 7:39 pm
Putoline in a small deep fat fryer is a very easy thing to use.
Posted : 19/10/2016 7:42 pm
I'm not a fan of Squirt. Despite following all the instructions it never seems to stay on long enough for any decent length of ride. I've tried it a few times and just given up on it.
For road use I still like Pedros Ice Wax. It seems to have better retention properties. Don't apply too much though.
ON the MTBs I've actually been using Muc Off Wet lube all year. It seems to need very little, stays on for ages and, importantly, doesn't leave a horrendous black residue.
Posted : 19/10/2016 7:50 pm
Wickens and soderstrum?
Posted : 19/10/2016 8:47 pm
Try this it's the mutts nutz
[url= http://www.ribblecycles.co.uk/rock-n-roll-extreme-lube/ ]Rock and roll extreme [/url]
Posted : 19/10/2016 8:54 pm
