Washer on cranks
[Closed] Washer on cranks
12 Users
What the view os Singletrack. Washer on pedal to crank interface or not???
Posted : 19/02/2021 3:35 pm
Depends on the crank.
Posted : 19/02/2021 3:42 pm
Aluminum??
Posted : 19/02/2021 3:43 pm
The only washers I have are where they are captive washers on the pedals. I only have alloy cranks tho
Posted : 19/02/2021 3:47 pm
Never done it, never had an issue, never owned carbon cranks.
Posted : 19/02/2021 3:49 pm
Depends more on the pedal - if it has a circular flange after the thread, then washer not really needed. If there is no flange and has a sharp edge for the pedal spindle flat, then a pedal washer is recommended (otherwise sharp edge will gouge a chunk out of your crank when tightened).
If the crank comes with the washer, fit it. Why wouldn't you?
Posted : 19/02/2021 4:37 pm
Straight in the bin every time.
Posted : 19/02/2021 4:38 pm
Raceface say yes on their cranks.
Posted : 19/02/2021 7:12 pm
If the cranks come with washers I fit them - why wouldn’t you? Think my Shimano slx didn’t come with them a few years back - but the alloy Raceface ones did - and all my Sram cranks did (alloy and carbon).
Posted : 19/02/2021 7:17 pm
Always use them as said above why not they are cheap another to buy.
Posted : 19/02/2021 8:08 pm
Always.
Posted : 19/02/2021 9:01 pm
Yes on carbon, no on metal (but would still put them on if a set came with them).
Posted : 19/02/2021 9:06 pm
