Warranty frame inco...
[Closed] Warranty frame incompatible parts
12 Users
Mates getting a very nice specialized replaced under lifetime warranty... his epic currently runs 2x sram xx new frames all 1x what happens regarding drive train? Any experience?
Posted : 09/07/2020 6:46 pm
Given its 2x in assuming its beyond the warranty on the bike and now just the (additional) warranty on the frame?
Friend might be lucky but there's no reason specialized should be replacing other parts under the extended frame warranty.
If the bike is still in warranty then the bike should be made good.
Posted : 09/07/2020 8:08 pm
No Spesh are not bound to replace everything.
The joys of long warranties and progression of bike parts.
Posted : 09/07/2020 8:20 pm
Mate would be a dick if he argued the point TBH.
Posted : 09/07/2020 8:31 pm
Did he buy a frame or a bike?
If he bought a frame and built it himself I would say his problem, frame is broken, they've replaced the frame.
If he bought a bike then I would say it's their problem, bike is broken, they need to make it work again.
In the real world, what's the issue? I assume nowhere to put a front mech, no cable routing?
Stick the front mech and shifter on fleabay, buy 1x chainring with proceeds
Posted : 09/07/2020 8:57 pm
If he bought a frame and built it himself I would say his problem, frame is broken, they’ve replaced the frame.
If he bought a bike then I would say it’s their problem, bike is broken, they need to make it work again.
This came up a while ago in another post, I'll try and find it.
However you are wrong. The frame broke. Specialized replace the frame. The parts on it - tough shit, they're under no obligation to give you a whole load of new drivetrain just because the spec has changed.
Edit: this thread: https://singletrackmag.com/forum/topic/warranty-bike-rebuild-460-for-parts/#post-11232359
Posted : 09/07/2020 9:00 pm
Thanks guys ... sort of settled an argument... full bike with lifetime warranty.... can see why its harsh though... imagine you've just changed rings chain cassette etc with 2x 10 XTR for example? Not riders fault frame breaks and new one wont take a front mech
Posted : 09/07/2020 10:45 pm
Mate had this a few years ago.
Cracked a newish 26" nukeproof mega which was under warranty
Except nukeproof didn't make the 26" frame anymore.
He'd bought a full bike but they only replaced the frame and he had to buy new wheels and forks
Posted : 09/07/2020 10:56 pm
Will it take a BB mount f-mech?
Posted : 09/07/2020 11:26 pm
 5lab
I know someone (in canada) who got a brand new bike when they broke the frame on their 26" stumpy after 3 years as the wheel size had gone up to 650b, almost nothing was compatible
Posted : 10/07/2020 6:10 am
 jimw
When I had three warranty frames from Trek (first warranty replacement broke after 30 miles use, the second after about three months!)it was made clear the only thing they would do is change the frame. Even stripping the old frame and rebuilding was my responsibility-hence a hurried strip down in the bike shop’s car park and the grateful loan of a BB tool from the shop mechanic.
The third frame had different geometry which meant the forks were no longer really suitable. I had to suck it up, but to be fair I did get the most expensive Carbon EX frame in the end as that was all they had in stock, so I did gain from it in one way. Trek and the bike shop were fantastic to deal with to give them their due.
Posted : 10/07/2020 8:46 am
Most brands will have a no consequential loss clause in their warranty, so technically are not liable for replacing incompatible parts, but will sometimes help at their discretion.
OP - no older stock warranty frames available?
Posted : 10/07/2020 8:57 am
I had a Specialized rockhopper top tier model that was last of the 26 inch wheels. The frame cracked and I got a replacement bike that was 29er but was the lowest model in the range. I was happy to receive it.
Posted : 10/07/2020 2:52 pm
