It’s time to take the plunge and treat my feet. What do you use or recommend? Thanks
Bontrager OMW
Bontrager OMW
Scott Heaters
Northwave do an 'artic' version of their winter boots which has a fleece lining. I wear mine all the time from now until easter as they're breathable but keep the mud out as well as the cold.
Their range seems to have grown somewhat but the raptor gtx artic looks like the closest comparison to my old celcius boots. The 'husky' boot looks like a Celsius in cheaper materials?
Either way, they've been by far the best £150 I've ever spent on cycling kit, makes winter riding completely normal (with Roubaix longs, waterproof shorts, a half decent top and a buff).
+1 on the raptor arctic boots. Currently £129 at tredz.
How cold and for how long? The simple answer is size up and wear thick, decent wool socks and an extra insole and a neoprene overshoes and leave wriggle room for your toes. I spent 5 days unsupported in the Arctic where my - 20c rated 45Nrth boots weren`t quite enough even with thick socks and overgaiters. Taking spare socks on a longer ride also helps as perspiration build up leads to cold feet.
Many thanks. The Bontys look good as do the NW arctic. I have poor circulation so even an hour or so in 3-4 degrees is no fun...
Sizing? Bontys seem to be up at least one full size, how about the Northwave?
I have had Northwave boots for a number of winters. The Celcius Artics seem to be generally a Euro size up from normal shoes and are suited to wider feet. They’re good and warm, but not completely infallible. I think the trick with poor circulation is not to make it worse by having too tight a closure or too thick a sock. The latest Raptors I found (at my expense) seemed to have a slightly narrower last. I’m looking at some 45NRTH boots for this winter but will continue with the Northwaves as well - they’ve been the warmest cycling footwear I’ve ever owned.
I bought a pair of Scott heaters gtx from start fitness at year in the sale with a 10% off voucher. I think they were about £60
https://m.startfitness.co.uk/scott-mtb-heater-gtx-mens-cycling-shoes-grey-240503-1001.html
I bought them fir cycling to work on. They have been so good I bought a 2nd pair for mtb. I haven't used my shimano mt91 boots since they arrived.
I've used Northwave but couldn't find a fit.
I’ll throw Lake MXZ303’s Into the mix, big clunky & warm. This year will be my fourth winter with them, I only wish I’d bought them earlier.
You need to size well up in the Northwaves. I'm normally size 11 but ended up with size 47 which they class as UK 12.5. Last thing you want with winter boots is them being too tight.
Shimano MW7 if using SPD, especially if your other shoes are Shimano. Been out in snow drifts with them, warm feet.
My only regret, not having bought winter shoes before (road or MTB) - really good. If you suffer cold feet/hands, then I'd advise to look at the more insulated ones.
+2 for the Scott Heaters... nice and roomy too.
Im going to +2 the Lake mx303s , for years ive suffered with cold feet and tried everything ,last year took a punt on there, even snow biking in the Lakes they were toasty warm with normal socks. So warm
Is there a warm dry winter boot for flats?
I use my OMWs with flats - Nukeproof Electrons. Just don't remove the SPD cover (or better - replace it with a softer one).
Plastic pedals are a good idea too btw - less of a heat sink (good reason for avoiding SPDs).
For winter SPD money you could buy any half decent waterproof waking boot.
For less extreme conditions I think 5.10 now do an 'EPS' version of the freerider which is insulated and has a 1 piece leather upper to minimise the amount of water that gets in.
Anyone have the Mavic Crossmax SL Pro Thermo? I think it’s between the Bontys and the North wave, I have shimano MTB spds but the MW7 just don’t look as warm.
The Lakes look lovely but not worth the extra layout?
Bontrager OMW
I also bought a pair of these boots and was rather disappointed in them compared to my much older Shimano boots.
They seemed more waterproof but colder than the Shimano .
Last month Halfords were doing a 30% sale on all cycle clothing and accessories. I'd been eyeing up some MXZ303s for a while now. So, using that discount plus BC10% plus Quidco that's less than £125 which seems fair as they are really good quality. Maybe wait to see if there's another sale on, perhaps even at CycleRepublic?
My only concern is that they are heavy (relative to my Lake MX237s) and you know what they say about rotational weight. However, for bimbling rides in the woods when it's really cold, wet and miserable or when there's snow on the ground these look like they're perfect for that. If this winter is like last winter then they'll be seeing a lot of use. I'll be waxing them first before I take them out. Amazing looking boots but expensive.
I’ve got some of the Bontys coming from Tritan for £130. Didn’t size up though, so I’m hoping they fit as I already have a pair of Bonty road shoes I figured the size would be the same.
Charlie the Bikemonger has some deals on 45Nrth boots @ £99/pr - never to be seen again at those prices.
I've recently got some of the Mavics and they are very comfy but do need sizing up as otherwise your constricted.
James
Lake MXZ303
Heavy but they do the job perfectly. They arent bad for walking in either. Roasty toasty
I’ve been looking at a pair of them Scott Heaters myself. What’s the advice on sizing for them relative to normal shoe size? Same, up or down?
After doing a bit of reading I went up a full size. Glad I did as you want to avoid compressing the inner boot.
Sealskin socks with thin merino socks under, and Keen sandals.
You did ask... 🙂
(And it works)
Bonni, I'm a size 10 in normal shoes.
Shimano, lake a 45.
Northwave 44 was too small 45 too big.
The Scott heater gortex is a 45 and a touch bigger than shimano but they have a draw string closure and 3 Velcro straps so they fit tight. It means I can run them with thick or thin socks.
North face chillkats are pretty good, comfy to wear, and so warm in -20c that i got sweaty and thought they were leaking.
i have ridden in them, but they were primarily bought for a winter holiday in canada.
Been swithering over omws my self.
They didn't have any wifesized available how ever ctbm had wife sized and me sized wolvhammers on sale.
I predict a warm winter ahead
Ah just seen the 45north boots on Charlie site. None left in 44/45 unlucky for me. They have to be the ultimate winter boot.
Iv used the Northwave Celsius GTX for quite a few years think I’m on my 3 rd pair. They are good boots if you can get the size right and can stop the water running down your shins and filling the boots.
That said I have often got back from group rides and watched mates wring out sodden cold socks while mine are still dry and toasty.
NW canyon gtx have been excellent lasting 5 yrs + starting to fall apart now so got some Lakes mxz303 last winter.. almost too warm? very well made in leather look like they will last forever making the £175 a bit more bearable.
£25 waterproof hiking boots from Decathalon and some merino socks. Trudged all round the Tweed Valley through a couple of winters and been fine... Some gaiters help too
Same as NorthCountryBoy here - been eyeing up the 45NRTH ones and was waiting to hear back on a sizing query and they’ve all gone! Ah well. Anybody got experience of the Japanther or is it worth holding out for the Wölvhammers to hopefully restock?
There was feedback suggesting the zip on the Japanther didn’t work well with mud, which would make me wary of the OWB’s but they’ve a lot of love on this thread
My Northwave boots are good but water runs down my legs and fills them up eventually.
TBH if it's warm enough to be muddy then I find the OMWs too warm to wear 😁
Does anyone know how wide those 45Nrth boots are…? I was about to blow two hundred and the rest on some wide fit Lake MX241 Endurance or MX237 Endurance shoes. I could afford pedals as wells as boots if they're wide enough…
I have 2 pairs of 45Nrth - Mk1 Wolvhammers and Japanthers - general advice is to size-up a Euro size for regular riding and 2 sizes for 'arctic' but they aren't wide-lasted.
dovebiker yeah, they really don't look very wide in the photos of the sole...
Interestingly the MK2 wolvhammers in almost all reviews say don't size up for normal riding .
The last is wider than the MK1.
I sized up anyway as there were no 44s in stock . I'll pad it out with an insole and socks when winter hits.
I've tried various techniques etc but have settled on neoprene socks inside normal summer trainers.
Goretex lined shoes are great but end up filling with water from top down and can't drain.
I kayak and canoe all year so 5mm neoprene socks work in that cold and wet environment.
How do they work. By filling from the top and keeping a layer of water against the skin and warm.
I'm.not worried about wet feet I'm worried about cold feet.
Won't be the first time I've had to commute in downjacket and snow boots.
Anyone tried the Northwave Himalaya boots? The spec looks good, but not many places have them and they’re pretty spendy. Looks like the same model is available but called the Yeti in Europe too.
I went for Northwave Raptor Arctic GTX and sized up following recommendations on here. I went for those over the Bonty's as they are less 'boot' like, mainly as I will be using them on my gravel/road bike as well as the MTB. I have skinny legs and look like a golf club in lycra tights and boots! I'll post once I have them and worn them in anger. Thanks for all the advice
Just came across this set of reviews for winter boots when looking for something else - https://singletrackmag.com/wp-content/uploads/2017/12/reviewed-8-pairs-of-winter-boots/
got a pair of wolvehammers last week. roll on winter.
