Want to change from...
[Closed] Want to change from 3 chain rings to 2
5 Users
I am fairly new new to mountain biking, I have already broken a few teeth off the big chain ring, I hardly use it so I plan to take it off and get a bash gaurd to protect the middle and bottom one, do I also need to replace the front mech and shifter on the handle bar or is there enough adjustment to stop it moving past the middle ring. Thought I'd ask before I start and create problems for myself.
Posted : 28/10/2012 9:25 pm
Nope leave it as is. You can tune it to work. You may want to consider increasing the middle ring size by 2 or 4 t though.
Posted : 28/10/2012 9:31 pm
Just chuck a bash ring on. Certainly no need for new mech and shifter.
Posted : 28/10/2012 9:32 pm
 nail
I have done exactly what you are proposing except that I changed my middle 32t ring for 36t which gives me sufficient range for my local terrain. I simply tighten the front mech adjuster screw to stop the mech moving over that far which also prevents the bar lever from clicking to the third position.
Posted : 28/10/2012 9:34 pm
Thanks for the advice
Posted : 28/10/2012 9:40 pm
 AD
Or buy a half bash and keep all three...
http://www.wiggle.co.uk/race-face-triple-half-bashguard-protector/
Although in fairness if you have already broken the teeth off the outer it'll be cheaper to buy a normal bash!
