Wahoo Kickr worth t...
[Closed] Wahoo Kickr worth the upgrade up from Core?
8 Users
Interested to hear views on whether the latest Kickr is worth the investment over the core from those that have used both?
Posted : 10/06/2021 10:43 pm
Given that this is STW, I'll both ignore your original question and recommend what I've got.
The Saris H3 seems to be very much on a par with the Kickr - arguably better in some respects, and is mid-way in price between the Kickr and Core - worth a look.
I have just swapped to one from an Elite Drivo, and it's much better. Pretty much silent - to the extent that I'm now noticing drivetrain noise and the speed of reaction to load in ERG mode plus load stability is massively improved.
Posted : 10/06/2021 11:06 pm
Another shout for the Saris H3, bought one in November as no Kickr-Core's in stock at the time. Very happy with it.
Posted : 11/06/2021 12:17 pm
I have had a kickr Core for two years now and cant fault it. I am not sure what the more expensive kickr would give you, other than a higher watt reading, assuming you are hitting 1800 watts or close to.
Is there a reason you are thinking of upgrading?
Posted : 11/06/2021 12:19 pm
 MSP
iirc the full fat core has a heavier flywheel for supposedly improved "realism" and auto calibration. I have had the core since it was released, and I am not sure that I would realy noticed the larger flywheel, and never bother calibrating it either so I wouldn't upgrade but may consider the full fat, or even the wahoo bike when it starts to die.
I guess it depends if you are using it as a serious training tool, or just a good way to get some saddle time and keep bike fitness when time and/or weather prevents you getting outdoors.
Posted : 11/06/2021 12:40 pm
NO, not if you already have the core.
Posted : 11/06/2021 12:52 pm
 feed
I upgraded a few months back (not from a Core) and was deciding between the Core and full V5 Kickr. Went for the full Kickr in the end but not for obvious reasons. The floor in my shed is a tad unlevel so the legs on the Kickr suit better, also have to move it around a fair bit so having the handle is good and the fold in legs allow it to pack away a bit neater. Also though, as I'm not planning on changing again, I just thought I'd spend the extra 'few' quid.
Is it worth the extra money? probably not. Do I regret buying the Kickr over the core? Nope
Was thinking at one stage of buying a Kickr Climb, glad I didn't follow through on that idea 🙂
Posted : 11/06/2021 3:30 pm
iirc the full fat core has a heavier flywheel for supposedly improved “realism”
No experience with either Kickr or any smart turbo for that matter, but I do look for bigger/heavier flywheels in my dumb turbos, supposedly better for knees if nothing else.
Posted : 11/06/2021 3:33 pm
