Anyone done this? Experiences?
Ive just changed mine from yellow to orange as i found i was using all the travel pretty much all the time (but yet not bottoming out ???). Now with the larger orange spacer added and running 30% sag (as before) the o-ring is stopping about 5mm from the end of the shaft even when i hit the 4' drop in my back garden.
Not sure which i prefer. Thoughts?
I weigh about 90kg if that helps.
Sounds perfect.
Thanks. Yeah it probably is. Ive just let all the air out and the o-ring is finishing at exactly the same spot as a fully compressed shock. Just might need a bit of getting used to in terms of feel as it has certainly stiffened up the back end on the drops and stairs in my back garden (my testing loop)
